Chicken Wire
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
Chicken Wire
Post by AandTman » Fri Feb 03, 2023 7:58 pm
Did the T's and TT's use chicken wire in their roofs ???
Thanks , Don
Last Name: Humble
Board Member Since: 2006
Re: Chicken Wire
Post by Humblej » Fri Feb 03, 2023 8:14 pm
No, Ford did not use chicken wire in any Model T.
Re: Chicken Wire
Post by John kuehn » Fri Feb 03, 2023 9:04 pm
As earlier stated Ford didn’t use chicken on any closed car or TT roofs.
I have a 24 Coupe and after replacing pieces of the wood roof frame parts I did use chicken wire in the roof when finishing it out. Some of the roof kits recommend it because it makes for a smooth roof which it does. Some don’t use it and it’s a preference I guess. To my way of thinking it doesn’t matter because it can’t be seen. I reasoned that there are also other improvement parts now being used such a bearings and etc.
But of course the original way it was done from the factory can be done too. To each his own I think.
Re: Chicken Wire
Post by Allan » Sat Feb 04, 2023 2:26 am
I believe "chicken wire" was used in early cars when it was necessary to form a compound curve in roof coverings. The chicken wire can be shaped to support the top fabric. As Ts never had anything but flat tops, shaping underlays were not needed. With no downward curves on the back and sides, and no need for a compound curve at the corners, there was no need for chicken wire.
Re: Chicken Wire
Post by TRDxB2 » Sat Feb 04, 2023 3:58 am
M&M speedster
Fabrikoid consists of cotton cloth coated with pyroxylin (a less nitrated nitrocellulose, dissolved in castor oil, alcohol, benzene and amyl acetate). Fabrikoid has been used for luggage, bookbinding, upholstery and dress trimmings
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Re: Chicken Wire
Post by tom_strickling » Sat Feb 04, 2023 9:28 am
Didnt Ford use packing crates from the various suppliers to make chicken coops and then used the eggs in the factory cafeterias ?
Oh no wait I'm thinking of floor boards.
This is supposed to funny.
Re: Chicken Wire
Post by TXGOAT2 » Sat Feb 04, 2023 9:45 am
I read an old article about Ford frugality. According to that article, they used everything that could possibley be used, including packaging and other "waste" in every way possible until just scraps were left. The scraps were burned in the powerplant if they couldn't be sold or somehow used in the manufacturing process. Ford's huge manufacturing volume made such frugality possible. They had to do something with all the dunnage and other incoming shipping material or they would have been buried in it.
Re: Chicken Wire
Post by TRDxB2 » Sat Feb 04, 2023 2:19 pm
The wood scraps where used to make Kingsford charcoal named after Edward George Kingsford
history https://www.mtfca.com/discus/messages/7 ... 09617.html
Last Name: Patrick
Re: Chicken Wire
Post by jiminbartow » Sat Feb 04, 2023 10:24 pm
I don’t know if Ford ever used chicken wire on the assembly line, but here are a couple of pictures in which modern day T owners used chicken wire on top of the wooden frame of a new roof on a 1926 Model T coupe. Jim Patrick
Re: Chicken Wire
Post by TXGOAT2 » Sun Feb 05, 2023 4:47 am
It would be a good idea to place felt or something similar between the wood and the chicken wire to prevent any chance of rattling or buzzing due to vibration.
Susanne
First Name: Susanne
Last Name: Rohner
Re: Chicken Wire
Post by Susanne » Sun Feb 05, 2023 6:39 am
M&M speedster
I always liked this approach - kind of like the old tube and fabric airplanes of the day. Actually, I considered doing something like doped fabric and tube for a speedster body - Of course, they would be a disaster if rolled, but you couldn't beat the weight savings... Also thanks for reminding me of the "recipe" for Pyroxylin... ;-)
Re: Chicken Wire
Post by John kuehn » Sun Feb 05, 2023 8:33 am
I used chicken wire in my 24 T Coupe and it’s doesn’t rattle, click or nothing like that. As tight as it’s pulled over the roof line I don’t see how it could. Putting in some kind of sound deadener is overthinking something that’s not necessary. But that’s my opinion. It all goes back if you want to put in an improvement or not in something you can’t see after it’s finished.
AandTman
First Name: Donald
Last Name: Vagasky
Re: Chicken Wire
Post by AandTman » Mon Feb 06, 2023 4:20 am
I guess chicken wire would have made the top smooth rather than wavey. I am getting ready to build a canopy top for my express bed with screen sides. I do believe i will apply chicken wire to the top. First, a layer of black fabric, then wire, then thin padding, then top material.
Re: Chicken Wire
Post by Allan » Mon Feb 06, 2023 6:18 am
Donald, if you space the slats in your roof with about 1" gaps, cover them with one sheet of natural coloured hessian/burlap, and them one layer of 1/4' thick polyester wadding like quilters use in their work, the slats will not show in the top covering. There is no need for additional chicken wire support.
Allan from down under..
Re: Chicken Wire
Post by Allan » Mon Feb 06, 2023 6:22 am
Donald, I missed the photo of the top you showed. It shows that there are just 7 slats in that roof. That means wide gaps, and that leads to the sagging between them. Close the gaps to approx 1" and the dips will go away.
AandTman
First Name: Donald
Last Name: Vagasky
Re: Chicken Wire
Post by AandTman » Mon Feb 06, 2023 10:45 am
Too late to change the cab wood now.............The top wood I had duplicated 7-8 years ago from what was on the truck. It was in good shape except for the slats. I assumed it was original. Anyway, I am making the canopy wood following the same pattern as the cab wood. This time chicken wire. I will probably redo the cab also.
AandTman
First Name: Donald
Last Name: Vagasky
Re: Chicken Wire
Post by AandTman » Thu Feb 09, 2023 10:23 am
And then I found this buy accident, I was on a road trip thru NM, several years ago, stopped at a museum and saw this inside. Was more interested in the additional brace in the C Cab. My memory had it that I saw chicken wire in a T's roof somewhere,......well there it is. I did not note at the time the condition of the top wood, original or replaced at some time, but from the pics, it looks like the top was replaced. And the front corner brackets are incorrect. Should have laid down some black material before the chicken wire.
jab35
Last Name: Bartsch
Re: Chicken Wire
Post by jab35 » Thu Feb 09, 2023 10:39 am
From a distance the backlighted cab roof resembles the chickenwire-reinforced window glass of the era, pretty cool, jb
AandTman
First Name: Donald
Last Name: Vagasky
Re: Chicken Wire
Post by AandTman » Thu Feb 09, 2023 6:11 pm
Ahhh,.... early sun roof...
Last Name: Patrick
Re: Chicken Wire
Post by jiminbartow » Thu Feb 09, 2023 6:23 pm
Are C-cabs not upholstered on the inside? If they are usually upholstered, that corner bracket would prevent it. Jim Patrick
Re: Chicken Wire
Post by RajoRacer » Thu Feb 09, 2023 7:45 pm
No upholstery except where your butt & back go !
