Obsolete obsolescence
Rich P. Bingham
Topic author - Posts: 1767
- First Name: Rich
- Last Name: Bingham
I suppose it's a moot point now that cotton linings of any quality are unavailable generally, but I wonder how many who felt they performed poorly followed the directions in the Ford "bible" suggesting to soak them in neatsfoot oil overnight before installing ? I did this 60 years ago and couldn't fault them. Installing the "questionable" last issue Scandinavia linings in my current Lizzie when she adopted me six years ago, again I soaked them as suggested. They're still giving good service.
Fair question, does the passing of Scandinavia bands mean kevlar will be the only option in coming years ? I don't hear much about wood linings lately.
Get a horse !
Mike Royster
- First Name: Michael
- Last Name: Royster
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout 1916 Runabout
Re: Obsolete obsolescence
I've been running Kevlar since 2007 on my 16 Runabout with no issues. If you drive and stop "normal" they are fine. If you drive and stop "hard" it could result with some issues. I like mine.
Bill Robinson
- First Name: Bill
- Last Name: Robinson
You know why you don't hear much about wood linings? Everybody who has the likes them. I run both Kevlar and wood linings. No problems. But, I do run auxiliary brakes on all of my Model T's.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
What was the function of neatsfoot oil in the initial set up of
cotton bands ?
cotton bands ?
A few comments and/or thoughts from me.
It saddens me to know that good cotton bands are not readily available. I have run Kevlar before, and have Kevlar ready and waiting to be put into my 1915 runabout. That is because I couldn't get good cotton linings that I believed I could trust. My 1913 has Kevlar on the brake, and my last two good old cotton linings on the low and reverse.
I ran cotton linings on several of my model Ts over the years. Loved them! I hadn't heard bout soaking in neatsfoot oil before, but I did fully soak then in fresh motor oil before using them.
My first model T speedster had cotton linings in it. I listened to the advice of some experienced model T owners (thank you Ed, et al!), and set them up right (a bit loose!), and kept them properly adjusted. I also used them properly, NOT gunning the engine or slipping the bands any more than absolutely necessary!
I drove that car for several years and drove it HARD! Calistoga Races, several Endurance Runs, a round trip to southern California for a Catalina Capers tour! I drove that car everywhere! It didn't have an odometer, but I kept a running track of mileage in my head. The low estimate on those bands? Eight thousand miles minimum, and they were still good. Don't tell me that cotton bands won't hold up!
Wood bands I rarely discuss. I imagine the ones in recent years are okay, and would consider them. However, the one car I did use wood bands in didn't work out so well. Full disclosure, it was a LONG time ago! And the wood bands at that time were not made by the fine people that have been making them for many years now! So, my and several other people's experience with them should not be taken seriously today. Sometimes (in those days!) they worked great! And sometimes, they wouldn't hold up at all. I suspect that the people making them in those days (there were a couple people making and selling them) were NOT being careful enough selecting the wood they used. I suspect that whether they held up or not depended on the lay of the grain in the wood,
The funny part of my using them, was that I was running a temporary tired old engine in a model T I had just resurrected. The low drum was BADLY scored! A 3/8 inch wide deep cut with sharp edges clear around the drum! I knew there was no way a cotton band could take that much abuse, and this was before Kevlar became available. I figured wood had at least a chance of conforming to the score in the drum, and it wouldn't cut and unravel like the cotton weave would. And it WORKED! I never had any trouble from that low drum! However, the brake didn't work so very well. The car had a great hand brake! An offshoot adaption with a very large drum that gave excellent service. I used the hand brake almost all the time. But the foot brake, using it only occasionally and lightly? One Endurance Run? Using the hand brake about ninety percent of the time? I had to pull the cover and adjust that stupid brake band three times in ONE day!
I only ran that engine for about two years. When I pulled the engine, and removed the bands? Low and reverse were still in fine condition, and eventually found their way into another model T. The brake band was worn almost completely through, and falling apart.(I checked it for round when I took it out? It was still round.)
Brent B, I am also a bit curious about soaking the cotton linings in neatsfoot oil. Just a thought? Maybe, I suspect the neatsfoot oil may soak in and adhere to the fibers in a better way and maybe just maybe it protects the cotton from the effects of moisture in the oil.
Something that is not consistent, but I have seen this several times. Cotton in band linings is like cotton cord in tires. Cotton is subject to a type of fungal infection that can lay dormant for a short time, or a long time. Initial processing does not remove it all, if it is there. In clothing, repeated washing will eventually remove it all. But in things like transmission bands and tire casings, if it happens to be there, and even microscopic moisture finds its way in? That cotton can rot to the fortitude of a sandcastle.
I have taken apart several old engines that have been sitting for years. I have pulled out oil soaked transmission bands that looked like they were brand new! But they had absolutely no fibrous strength at all! A perfect looking weave, soaked in old oil, yet they turned to dust in my fingers.
We know condensation contaminates the oil with small amounts of water. Could it be that water was enough to activate the fungal infestation natural to cotton? And in spite of all the oil also present, rotted the cotton fibers?
Believe me. I have my doubts about that whole hypothesis. Between the oil and the engine heat? How could it survive at all? But it is something to wonder about. And I have seen enough thoroughly rotted oil soaked bands that something had to get to them.
Regardless. As much as I wish I could buy some really good cotton bands? (For a reasonable price I can afford?) I can live with Kevlar, or wood if they continue to be good. And, if things get worse? I suspect I could make something myself (maybe leather???) that might work okay?
JohnH
- Last Name: Hunter
- Board Member Since: 2002
Maybe it's just the way I drive, but I've had excellent results with cotton linings. Mark Automotive were the best, but both the old and new (supposedly inferior) Scandinavians have also performed well. Typically I get around 6 to 8 years out of the brake lining, and have had 10 years out of the low lining when it was a Mark automotive. I've always soaked them in ATF before rivetting.
Now that cotton linings are on the list of no longer produced parts, I'll be going to bonded linings when my stock runs out.
BUSHMIKE
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Bonded linings? Please elaborate.
Rich P. Bingham
- First Name: Rich
Nothing said as I recall as to the reason. I'm thinking it's reasonable to assume that well lubricated lining will wear better, and that a "dry" one will not ? Neatsfoot oil is light and penetrates absorbtive materials very well. After soaking, the linings were thoroughly saturated. Of course you soak the lining after they have been installed on the bands.
Get a horse !
Neatsfoot oil may not dissolve in motor oil, or some ingredient in it may not. Beeswax resists petroleum oil and some solvents. As for organic linings, dirty motor oil that has become acidic would probably attack wood or cotton linings over time. Oil that is moisture-cut might also promote decay of organic linings. Modern synthetic oils seem to work well with the various band linings. They certainly give good results with Kevlar lining.
Rich P. Bingham
- First Name: Rich
Get a horse !
jsaylor
- Last Name: Saylor
Bonded linings were popular for a while in the 60-80 era. They were a very hard industrial lining that was glued / bonded to the band. They were harsh, chattered, but wore forever. I ran some back then but when I saw the wear on the drums, I went back to cotton and then kevlar when it came out. I still have some of those bonded bands on the shelf and tried to remove the lining but its on there forever and will have to be ground off.Bonded linings? Please elaborate
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
The bonded linings referred to above used the same friction material as modern automatic transmissions. My recollection was the chattering may well have been due to running them on trans drums with worn bushings. It was a common problem back then, but the biggest issue was that they did not play well with the relatively soft cast iron drum material. Drum wear was a problem with them.
JohnH
- Last Name: Hunter
Bonded linings were popular in this part of the world a while back. I've driven a high mileage 26 tourer with them, and the drums looked perfectly OK when we had the powerplant out. The only difference in driving was they were a little bit more 'grabby', but they didn't chatter. I know of a TT in regular use also with bonded linings, and there's no complaints about it. I think it comes down to what material is used for the bonded lining. When I had the hub brakes bonded I had a choice to two materials, and tried both. Not surprisingly, the softer material was the smoothest in action.
Brake lining and other friction material comes in a number of variations, with some being "fast" or soft lining, and others being hard. The "soft" lining needs less pressure to work and usually has a better "feel", but it wears faster. Hard lining requires more pressure and probably causes more wear to drums, discs, etc. I imagine that most all friction linings vary similarly, with some being better suited for particular applications and some less so.
kmatt2
- Last Name: Matthiesen
Back in the mid 1970’s I knew the person doing the bonded Model T transmission bands in Central California area. The linings were the same material as was used in old cable operated dragline brake drums that stop and hold the cables in use. Many such draglines from the 1950’s were still in use by irrigation districts back then. On the T bands they worked well but required a few filed notches to allow oil to reach the drums when not being applied. Just like with today’s wood bands they required removing the hogshead to install to keep them round, also like with Kevlar, over slipping of the drums wasn’t good on the drums. They worked well with proper use in a time when the only other option was the new cotton bands that weren’t made quite like the older cotton bands were made in prior years. Today we have wood and Kevlar and both have their pros and cons but both can work well.
