Testing a magneto horn
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Thu Feb 23, 2023 10:34 pm
I have a decent magneto horn that will never use since my cars have generators. I would like to test it to confirm it works before offering it for sale. Any hints on the best way to do that using my car?
Re: Testing a magneto horn
Post by Steve Jelf » Thu Feb 23, 2023 10:55 pm
One wire from the mag to the terminal on the horn. Ground wire from the horn body to the car body/engine/frame. Adjustment screw is in the center of the diaphragm.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Thu Feb 23, 2023 11:29 pm
Sounds good.
Post by Allan » Fri Feb 24, 2023 2:38 am
The adjustment screw is in the centre of the diaphragm, deep in the trumpet. I made a tool to do the adjustment , consisting of a socket wrench welded to a steel tube, and a T handled screwdriver with long shaft to drop down the tube.
