Need help identifying front fender
frank.koonce
Topic author - Posts: 21
- Last Name: Koonce
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Roadster, 1927 fordor
[image][/image][image][/image]
Hello, I have a 1915 runabout that needs a right front (passenger side) fender. I have what I think is a correct left fender, with three rivets, a bill, and a flat top. A friend brought me the red fender, which also has three rivets, thinking that it was what I needed. However, as you can see in two of the attached pictures, it is wider than mine and has a bill that is shaped differently. I am thinking that the red fender may be off of a speedster or a torpedo. I would be very grateful if anyone could solve the mystery.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
Re: Need help identifying front fender
I believe the wider fender is a wide track fender for a wide track T seen here.
Moxie26
- First Name: Robert
- Last Name: Jablonski
Ed, I agree with you those wide track Fords were sold mainly in the southern states
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Definitely wide track. I have a pair of them. I advertised them a couple years ago, there was no lnterest
- Last Name: House
Yep
You guys are good ! Also known as southern tread.
Wide track. I might be interested in it. I have an early 15 widetrack. The fender was severely damaged @ some point in its life & has the scars on the underside to prove it. Interestingly it has 4 rivets holding the mounting bracket.
frank.koonce
- Last Name: Koonce
Thanks to everyone for their replies. Problem solved!
Frank
Frank
