Have 12v Hitachi with external voltage regulator
Miss placed my wiring diagram
That in advance
Alternator wiring diagram
Re: Alternator wiring diagram
Hitachi made/makes several different 12v alternators. Where did you get it?
Snyder mentions replacements for the Mitsubishi style alternators that had the external regulators.
Texas T has some instructions for their DELCO Model T alternator https://www.texastparts.com/mm5/manuals ... LT-12V.pdf
Waldo
- First Name: Doug
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 21 touring
The hitachi alternator requires an additional wire or two for the exciter - the Delco is a single wire. THe do not wire the same
Can you post a picture of the external voltage regulator and what model Hitachi Alternator you have. There are lots of different ones for each.
Nv Bob
Topic author - Posts: 799
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Thanks I got it sorted out
