Brass top coils
Danny Carstensen
Topic author - Posts: 29
- First Name: Danny
- Last Name: Carstensen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1922 Roadster
- Board Member Since: 2014
Brass top coils
Are the capacitors the same in all coils, and the points look to be either style?
- Last Name: Tannehill
Re: Brass top coils
Ron or Brent would be the go to for a more detailed answer however it is my understanding late 1913-forward that’s correct but I stand to be corrected.
Danny Carstensen
- First Name: Danny
Re: Brass top coils
Thanks John. Will do some more checking. Have some coils I would kike to work on.
Re: Brass top coils
Danny be aware that the way that the wires attached on the inside are slightly different on brass top coils than the regular coils.
With the exception of the bolt with the spring tensor, the wires that go to the points and bridge on the brass top actually go through the top wood plate and are soldered to a rectangular piece of metal that has slots for the small metal carriage bolts to lock into. Those bolts may feel loose if you disassemble the points. Some folks solder them into the plate where the wire connects. I have not but I do make sure they are in the slots before tightening the new points down. Others may have a better technique. Best John
