Who developed Model T three point suspension?
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Sun Mar 05, 2023 4:06 pm
I was discussing transverse spring suspension with a Model A guy, and it got me wondering who developed three point suspension for the Model T? Did they innovate it themselves, or did they copy someone else?
Re: Who developed Model T three point suspension?
Post by DanTreace » Sun Mar 05, 2023 4:27 pm
Rather sure Henry done it ;)
Then Henry improved on the patent with this issue, has the transverse rear spring.
Image 3-5-23 at 4.43 PM.jpeg (57.76 KiB) Viewed 2373 times
BuddyTheRoadster
First Name: Chris
Last Name: Rini
Post by BuddyTheRoadster » Sun Mar 05, 2023 5:55 pm
Thanks! Henry took out the patent at least for both the Models NRS and Model T suspension. That explains a lot.
Post by TRDxB2 » Sun Mar 05, 2023 9:50 pm
Breaking the original question into two questions"
1 "..who developed three point suspension for the Model T?" for the Model T was Henry Ford. Note the picture a
2 "who developed the three point suspension" Unknown but this 1905 ad predates Henry's adaptation.
marmon 2.png (283.13 KiB) Viewed 2255 times
Jim Eubanks
First Name: Jim
Last Name: Eubanks
* REQUIRED* Type and Year of Model Ts owned: 1926 touring, 1927 cpe
Post by Jim Eubanks » Wed Mar 08, 2023 8:46 am
Henry designed most of the first Cadillac and looking at a 04 model I can see a lot of Ford in it.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Wed Mar 08, 2023 9:08 am
Henry did not invent the 3 point suspension. He has his name on a patent dated 1913. And it has to be stressed that Henry did not invent the automobile.
Automobile for 23 January 1906, "1906 Frame and Spring Construction," page 232. " The three point suspension, an old desideratum in automobile construction has found more general application in 1906 cars........(an) example of the 3 point suspension can be found in the Stevens-Duryea..."
I believe the Marmon is one of the first automobile companies to be given credit for the three point system.
Post by TXGOAT2 » Wed Mar 08, 2023 10:21 am
Ford was probably the first to apply the 3 point system in a mass-produced "modern" layout vehicle with front mounted en bloc engine/transmission, enclosed rear shaft drive, and transverse leaf springs.
George Mills
Last Name: Mills
Post by George Mills » Wed Mar 08, 2023 10:33 am
While it is given that 3-point suspension probably existed as a load distributing concept long before Henry came along, and today such a patent like 1075557 wouldn't get past first base with an examiner as written, it also probably didn't get past the examiner at the time!
Henry filed in July of 1909 and the patent issued in October of 1913. During that era, patents typically went through the system in a matter of months...so why did this one take 4 years?
One reads stories about patents that say that applicants used vague statements hoping to delay the actual patent issuance by using the examiner challenges as a delaying tactic and a bit of that may be true by intent...but the reality is that there was NO requirement at the time to disclose similar patents or even reference patents as there is today. Once submitted, the words 'patent pending' are allowed to be used supposedly not in marketing, but hey...so it goes. As to the final ruling? The same rule applies then as now, the examiner has the right to determine 'unique and novel' based upon the examiner own knowledge and the so-called preamble to the patent application that 'explains' things. (This one does happen to be very windy even though it is an improvement in the prior patent!)
My guess would be that Henry and his attorney did not use delaying tactics as some of Henry other patents did fly through the system, however, on initial rejection Henry and his attorney 'eventually' convinced the examiner that things were 'unique and novel' after much back and forth. There is something called a 'wrapper' in the patent office files that follows the chronological back and forth history on a patent application through issuance, but that is not an online thing.
In my (humble) view, the use of 'In an automobile...' as the opening words to most of the claims followed then by what Henry thought was 'new', strongly suggest that therein lies what Henry sought to prove 'unique' or equally, why the original examiner kept sending it back! Finally, Henry won...or better said Ford Motor Company 'won' as also in the era...an inventor got a salary and wages...the company owner had the right to claim any ensuing patent from 'the paid for work'.
hull 433
First Name: Stan
Last Name: Gadson
Post by hull 433 » Wed Mar 08, 2023 11:04 am
Three point suspension? Oh, you youngsters.
Post by TXGOAT2 » Wed Mar 08, 2023 11:07 am
Cugnot's machine had 3 wheels....
hull 433
First Name: Stan
Last Name: Gadson
Post by hull 433 » Wed Mar 08, 2023 11:26 am
but Cugnot's boiler . . .
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Mar 08, 2023 1:33 pm
Three legged milking stools were around long before automobiles.
Art Mirtes
