I Doubt I Will be Able to Find One of These!
BLB27
First Name: Bruce
Last Name: Brakke
Post by BLB27 » Wed Mar 08, 2023 1:41 pm
I lost one of the fender washers for my 1927 coupe. Dose anyone have an extra? If not, can anyone suggest how to make something that would replace it?
Distagon2
Re: I Doubt I Will be Able to Find One of These!
Post by Distagon2 » Wed Mar 08, 2023 1:49 pm
Go to Lowes or Home Depot-they sell different size fender washers. Shouldn't be too hard to find one.
Having said that, I don't recall that a washer like that was used originally.
Post by TXGOAT2 » Wed Mar 08, 2023 2:25 pm
My 26-27 car has carriage head bolts at that location. No washers on outside. Carriage bolt head is about 3/4 diameter, bolt shank is 3/8 or 5/16 with washer & hex nut thru fender brace.
Distagon2
Post by Distagon2 » Wed Mar 08, 2023 8:50 pm
Looks like someone used the big washer due to what appears to be a wallowed out hole in the fender.
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Post by fordt » Wed Mar 15, 2023 2:34 pm
Shouldn’t the two bolts where the fender attaches to the frame be one hex head bolt thru the frame and bracket and one carriage head type bolt that goes thru the wing on the frame, the bracket and the fender? Lang’s shows all hex head bolts….
Post by John kuehn » Wed Mar 15, 2023 6:52 pm
I believe that’s a random washer that was used to keep the hole from getting bigger. It’s not a surprise to see a patch up used on a Model T. Sometime in the past a previous owner used what he had and was happy.
