Mystery Tool identification
Topic author - Posts: 86
- Last Name: King
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 25 Coupe, , 26 Touring, 22 Aluminum Fordor, 23 Coupe
- Board Member Since: 2010
I bought 2 large trailers of T parts and this tool shown in front of the drum stack was in the mix. Does anyone know what it does? is it T related? B.S.V.CO embossed on the bottom.
- First Name: Jack
- Last Name: Putnam
Re: Mystery Tool identification
Maybe tenon cutter?
- Last Name: King
Looks like a file could slide in the rectangular slot and the disk would index to select a hole size
- Last Name: King
A look from the bottom.
- First Name: Ed
- Last Name: Martin
- Last Name: Strange
- Board Member Since: 2013
- Last Name: King
Thank you guys. Thanks for the video link! Looks like I would need to find the cutter that mounts in it to make it complete although I'm not sure I'm ready to take on building a wheel. Wheel wrights are a craftsman on a different level and probably need excellent patience. My background having retired as a steamfitter and paper machine mechanic doesn't always lend itself well to this hobby.
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Would the square tapered end fit in a hand brace? My dad had an antique drill press that took that type of tapered head. You could run it from a flat belt or hand crank it.
Besides the missing blade, one would also need the cone cutter to get things centered and started.
https://www.woodworkersjournal.com/cham ... er-dowels/
