New Rear Axle Truss Rods?
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Sat Apr 01, 2023 11:47 am
I recently saw an ad for truss rods for supporting earlier rear axle housings being newly produced but can't seem to find it again. Has anyone seen this and can point me toward it and/or who is making them?
Sean Butler
Huntington Beach, CA
Re: New Rear Axle Truss Rods?
Post by TRDxB2 » Sat Apr 01, 2023 12:23 pm
The seller https://www.modeltranch.com/show_produc ... Product=71
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sat Apr 01, 2023 12:57 pm
Sean, I sent you a picture of the one I made for the Torpedo several years ago. Seems to be working fine
1912 Torpedo Roadster
Post by TRDxB2 » Sat Apr 01, 2023 1:04 pm
Post on making the rear truss rod brackets etc https://www.mtfca.com/discus/messages/4 ... 75167.html
Sean Butler
First Name: Sean
Last Name: Butler
Post by Sean Butler » Sat Apr 01, 2023 10:40 pm
Thanks Frank. That's the one I had seen. And, thank you Gene - as always. Can anyone speak to personal experience with the new truss rod? I have read posts from the past on how different years' axle housing diameters, being different at the point that the clamp mounts was a concern.
Sean Butler
SurfCityGene
First Name: Gene
Post by SurfCityGene » Sun Apr 02, 2023 1:37 pm
The thing I worried about was how much tension should be on the truss.? Maybe others will add some insight about how to determine the proper preload?
