roadster body
joshboogie
Topic author - Posts: 19
- First Name: josh
- Last Name: king
roadster body
What is a roadster body worth that has been rewooded upolsterd painted red that is a 1915 ?
Re: roadster body
Are you buying or selling?
I don't see any ads for one but a '26'27 is for sale for 1,995 on eBay.
A wood kit is $1400 Approx.
I would guess $4,000 to $5,000 might be a place to start.
Perhaps $3,000 would be more reasonable.
Just my opinion at the moment.
Others will have their own ideas.
- Last Name: House
Re: roadster body
I concur $3K-$3.5K. Add 400 for a turtledeck.
Re: roadster body
If the roadster body and the turtle deck is rewooded and it’s done pretty well I would say no more than $4000.00. .But that’s if it was really nice.
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: roadster body
You need to remember that that body on an unrestored chassis would only pull 3500-4500 in this market. Red is not a great selling point either.
Andy
Andy
Les Schubert
- First Name: Les
- Last Name: Schubert
Re: roadster body
IF it had both front doors (Canadian version) it would probably be worth more as they are considerably rarer in my experience. I wanted one and ultimately I bought a US version and converted it!!
Nv Bob
- First Name: Bob
- Last Name: Middleton
- * REQUIRED* Type and Year of Model Ts owned: 18 roadster 1810 brand X
Re: roadster body
If your selling I'm interested
3-3500 range
3-3500 range
Re: roadster body
Also depends on condition of sheet metal. Rust out or big dents would cause it to be worth less. Also, has the metal been sealed behind the wood. It should have a good coat of acrylic primer on the inside at least.
joshboogie
- First Name: josh
- Last Name: king
Re: roadster body
It was primed and rewooded and upolsterd by Charles Shaver and the body and paint was done by a pro so no dents I can sea.
Re: roadster body
Post some pictures. You will get a better educated view on its value.joshboogie wrote: ↑Tue Apr 11, 2023 4:02 pmIt was primed and rewooded and upolsterd by Charles Shaver and the body and paint was done by a pro so no dents I can sea.
Re: roadster body
Odd that this older thread should pop back up with a lame response at this time with Steve J in the hospital?
Makes one wonder.
Also makes one wonder what ever became of the OP body in question?
Makes one wonder.
Re: roadster body
Not everyone will be thrilled about it being painted red. That may bring its value down a bit.
Re: roadster body
What is the difference between a 27 Canadian body and a 27 U.S. body? Both have doors on both sides. And both have steering wheels on left side unless manufactured for sale in a country which drives on the opposite side of the road.
John Codman
- Last Name: Codman
Re: roadster body
You are correct, but the body in question is a 1915.Norman Kling wrote: ↑Mon Sep 11, 2023 10:54 amWhat is the difference between a 27 Canadian body and a 27 U.S. body? Both have doors on both sides. And both have steering wheels on left side unless manufactured for sale in a country which drives on the opposite side of the road.
TMiller6
- First Name: Thomas
- Last Name: Miller
Re: roadster body
I hope I’m not going too far off topic. To answer Norman’s question, I have seen three differences in 26-7 Canadian bodies:
Firewall stamped with plant code. Example Montreal is abbreviated
Robertson screws
The body crossmember behind the front floorboards has two “tunnels” near the starter switch whereas US cars have only one on the left side
Robertson screws
Tom Miller
Re: roadster body
Keep in mind that many 1915's are not really the real thing either. Keep that in mind when looking at them. Do your research!
