Do it yourself plate of small items. Recommendations
Topic author - Posts: 2434
- Last Name: Patrick
Can anyone recommend an affordable setup enabling one to professionally electroplate plate small items himself? Thank you. Jim Patrick
- First Name: steven
- Last Name: davidson
Re: Do it yourself plate of small items. Recommendations
What type of plating? If it's nickel, you tube has a number of videos. It's very simple, and very cheap. Hardware store items
YouTube does indeed have some very good videos and instruction...I'll add that Caswell is pretty much the go-to place for do-it-yerselfers
Jim,
Check this out. I have never before seen such a user friendly, easy to understand technique. I will state however that I have not yet tried it.
Start at the Page #3, 9/21/2021, 7:35PM entry... https://www.owwm.org/viewtopic.php?f=1& ... r&start=30
- First Name: William
- Last Name: May
I second Scott Congers endorsement of Caswell Plating. I have their setup for zinc for doing early fasteners, and it works wonderfully and gives a perfect looking product. It isn't silver cadmium, but it's as close as you can get nowdays.
- Last Name: Pharis
I’ve set up for small scale copper and nickel using vinegar. This works for hardware sized parts, stronger acids are said to work better on larger parts…
