1926 Model TT Height
CatGuy
Topic author - Posts: 354
- Last Name: Hunt
- * REQUIRED* Type and Year of Model Ts owned: '26 Runabout
We are not moving, but will need to expand the garage! I'm hoping someday to get a '26 TT that needs to be restored (it's painted, but not assembled). In trying to figure out the dimensions, I have that they are approximately 65" wide and 155" long. What is the height of one? It has the enclosed cab.
rwephill
- Last Name: Evans
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT C-Cab
Re: 1926 Model TT Height
Sounds like your TT project is at about the same state as mine. Finishing the cab and getting ready to put it back up on the frame. I have a C-Cab, but I know that both factory cabs are quite tall. Though I cannot answer your height question exactly, I can say that they will not fit in a standard 7' high garage opening. We need garage doors that have one additional panel for height clearance.
Good luck with the completion of your truck.
“You don’t have to go fast… you just have to go.”
BUSHMIKE
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Both my TT’s with steel closed cabs are 7’2”. One is on 23’s front and rear, the other 21” front and 20” rears.
Burger in Spokane
- First Name: Brent
- Last Name: Burger
- Board Member Since: 2014
Mine is 84" to the high point at the back of the cab.
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
Scott,
Every Model T is different.
Every Model TT is different.
Make your door as tall as possible.
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
TheSaintDiscJockey
- First Name: Brooks
- Last Name: Schlieben
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT
Jacob Mangold
- First Name: Jacob
- Last Name: Mangold
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT, 1924 TT, 1928 A Coupe
- Board Member Since: 2023
My ‘24 TT is just above 7 feet tall. Probably 7 foot 1 inch. Mine is a standard cab, not a c cab. They are pretty darn tall.
26modeltt
- First Name: Jack
- Last Name: Leonhardt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
Our '26 Closed Cab TT w/ 650-20 rear tires and 450-21 front tires has a height of 85 3/4"
