Need help identifying this part
jwrightjr
Topic author - Posts: 116
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
Acquired this transmission cover.....well not the usual transmission cover. Is it a spedo drive? Says Nash Transmission Drive but fits on the T.
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
John
Martin, Ohio
John E. Guitar
- Last Name: Guitar
- Board Member Since: 2012
Re: Need help identifying this part
Nice find ! That internal drive gear is quite rare to find !
The Patterson drive was similar in operation, but much less complicated to fit. As mentioned, the drive gear on the transmission is much harder to find, for both types. If anyone has a spare fibre gear for the Patterson cable, the one that goes on the cover end and engages the spiral gear on the transmission , I could use one.
jwrightjr
- Last Name: Wright
Thanks for the replies! The drive gear looks like it may never have been ran. Not sure what I'm going to do with this. Without the other pieces it is a wall hanger. Problem is I am running out of wall! Not sure what this is worth or if anybody could use it shoot me a reasonable offer. Suppose I should post this in the classified section.
Kind Regards
John
Martin, Ohio
John
Martin, Ohio
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
- First Name: Dennis
- Last Name: Seth
I have that set up on my '22 Coupe, but I am missing the internal cable to the speedometer. I have all the drive gears, exterior cable and the speedometer, just not the internal cable.
