1917 Carburetor ID
m_p_dean@yahoo.com
First Name: Maurice
Last Name: Dean
* REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
1917 Carburetor ID
Post by m_p_dean@yahoo.com » Fri Apr 07, 2023 3:58 pm
I need to do some carb repairs on my '17 touring car, but I'm not able to ID the carb. Hopefully I've attached a picture. I've added an arrow indicating a cap on the top, between the throttle shaft and the needle, that my help in identification.
Thanks for your help, Maury Dean
Russ_Furstnow
First Name: Russ
Last Name: Furstnow
Re: 1917 Carburetor ID
Post by Russ_Furstnow » Fri Apr 07, 2023 4:05 pm
Kingston #6100 Model L-2, Used in 1917 and 1918. I hope this helps, Russ Furstnow
m_p_dean@yahoo.com
First Name: Maurice
Last Name: Dean
Post by m_p_dean@yahoo.com » Mon Apr 17, 2023 4:52 pm
Thank you, Russ
Post by TRDxB2 » Mon Apr 17, 2023 6:39 pm
Rebuilding the L-2 Instructios https://modeltfordfix.com/rebuilding-th ... arburetor/
Lots of info on Kingston Carbs scroll down to the L-2 https://modeltfordfix.com/the-kingston- ... el-t-ford/
