Lower radiator shell screw size
Plankhill
Topic author - Posts: 136
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
What is the screw size for the screw that holds the lower radiator apron to the front motor mount on a 26-27?
Moxie26
- Last Name: Jablonski
Re: Lower radiator shell screw size
I believe it's the same screw size and design that holds the inspection door on the transmission
That button head machine screw for the '26-'27 radiator apron with the 3075D spring clip/motor mount with the threaded hole is Fac. # T-8004. The size is 1/4 x 20 x 3/8" long. Some times a washer is needed under the screw if the hole in the apron is worn larger.
The hogshead cover door screw is also button head, but larger, as it's 5/16" x 18 x 3/8"
Moxie26
Thanks for the clarification Dan, appreciated.
SurfCityGene
- First Name: Gene
- Last Name: Carrothers
Just did one yesterday and looked like 1/4 - 20TPI
1912 Torpedo Roadster
