Question using aluminum rear seals
Terrye
First Name: Terry
Last Name: Eastin
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
Post by Terrye » Fri Apr 21, 2023 9:37 pm
When using the aluminum seals for the rear axles. Do you need to put a steel washer on outside of the bearing before installing the aluminum seal. Would this keep the bearing from cutting the seal.
Re: Question using aluminum rear seals
Post by DanTreace » Sat Apr 22, 2023 9:10 am
Won't need that steel washer with the modern alum cap.
The seal is placed deep into the body of the cap, and Hyatt face can't contact the neoprene seal.
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Sat Apr 22, 2023 11:18 am
Just make sure you have the right size. The OD of the axle housing is a little smaller pre-1919 and larger from them on. A Ruckstell housing uses the larger size.
Post by Rich Eagle » Sat Apr 22, 2023 11:33 am
I have had the key slide into the seal and cut it. (during assembly) I have used a thin washer but a tight-fitting key would make the washer unnecessary.
Those new seals are pretty nice.
Harvey Bergstrom
First Name: Harvey
Last Name: Bergstrom
Post by Harvey Bergstrom » Sun Apr 23, 2023 10:04 am
I installed the new style seals on my ‘24 touring when I installed new axles. Should not have oil drips anyway and keep wheels clean!
Last Name: Juhl
Post by Oldav8tor » Sun Apr 23, 2023 11:11 am
Some tape over the axle taper during install can protect against cutting the neoprene seal. No steel washer required.
