Mag voltage while cranking
Modeltmike
Last Name: Sleep
* REQUIRED* Type and Year of Model Ts owned: I have 22, 24, 26 coupe, 25 pickup, 23 roadster, 22 center door, 23 touring, 21 touring and 26 Fordson.
Post by Modeltmike » Sat May 11, 2019 10:36 pm
What voltage should you get with an analog A/C voltmeter at the mag pickup point when cranking? I’m looking at a non running car that has sat for years and wondering if mag is functional. There maybe other simple test, and open for ideas. Thanks
Re: Mag voltage while cranking
Post by Scott_Conger » Sat May 11, 2019 11:15 pm
A couple of volts
pull 4 plugs out, have someone place leads and a 6V bulb across mag post and ground and have them watch. Spin the engine and the bulb should flicker/flash, though not very brightly.
if it has been sitting for a long time, you might wish to jack up the drivers side rear wheel, place handbrake lever in "neutral" and have a go at it. This will be the least resistance to cranking that you will be able to achieve and thus the highest mag speed.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Sun May 12, 2019 3:48 am
Mike ; As soon as I mounted the Coilring and Flywheel , I test the mag output . When I crank as fast as I can, then I have about 3 1/2 V AC .
Toon
ABoer
Last Name: Boer
Post by ABoer » Sun May 12, 2019 3:56 am
Scott ; Why jack up the drivers side rear wheel , and not the passenger side ????
Toon
Post by Scott_Conger » Sun May 12, 2019 7:52 am
Anthony
either, or both wheels works
I suppose if you do both, you take the differential out of the equation
Modeltmike
Last Name: Sleep
Post by Modeltmike » Sun May 12, 2019 1:02 pm
Just checked. Looks like just over 2 volts with hand crank. May not be a good mag, but likely is a functioning mag. Thanks
