Engine serial number
johnernst
Last Name: Ernst
* REQUIRED* Type and Year of Model Ts owned: 1922 Canadian Touring
Post by johnernst » Thu Apr 27, 2023 2:39 pm
I have recently purchased a 1927 Model TT and am doing a bit of research on it. The engine serial number is SC749255. Obviously the C is Canadian but I dont know what the S is for. Also the number is much higher than known list of Canadian engine serial numbers. Does anyone have any further information? Thanks John Ernst
Re: Engine serial number
Post by speedytinc » Thu Apr 27, 2023 2:41 pm
Looks like a re number job.
Look around here for other number stampings & compare.
Last Name: Hatch
Post by Dan Hatch » Thu Apr 27, 2023 2:53 pm
Look on frame under passenger door. Should be a number there. Should match engine number. If not engine has been changed.
Post by Scott_Conger » Thu Apr 27, 2023 2:56 pm
To say that the "C" is obviously for "Canadian", is a leap of faith. It's a renumber job. Like Dan said, check the frame # and that will be what the original engine sported, too.
Edit 4/27 7:28PM
enough evidence presented to believe that the "C" either was original or is possibly intended to mean "Canada". My original post is flawed. Still believe it is a renumber job, though.
Post by Steve Jelf » Thu Apr 27, 2023 5:11 pm
In the encyclopedia Bruce doesn't mention S being on Canadian engines, which he would certainly have done if it had been a factory practice. In the USA replacement blocks were sold without serial numbers, with the expectation that they would be stamped with the number of the presumably ruined engine they replaced. If the same thing was done in Canada, I gather this is one of those replacement blocks.
Post by TRDxB2 » Thu Apr 27, 2023 6:59 pm
Canadian? Number is too high. SC749255 also the reasonable presumption that the S extra & the C is for Canadian, rather than the SC stud for something itself- SeCond, Smith's Car service
Restamp / cover up?
Looks like a 4 and its not the same shape (top^). Different 9 --- but not enough Canadian engine number stamps to conclude anything. What would be interesting is to see what the size of the casting area above the water inlet is for a late Canadian Block for comparison
Post by RajoRacer » Thu Apr 27, 2023 7:19 pm
John - hate be be a "Betty Bummer" but that engine is earlier & not a '26 - '27 !
Perhaps I misspoke - looking at your carburetor thread, I see the "Made in Canada" on the head - does it have the wide clutch & brake pedals ?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Apr 27, 2023 7:59 pm
Is Made in Canada cast on the block?
johnernst
Last Name: Ernst
Post by johnernst » Thu Apr 27, 2023 8:53 pm
It does have wide pedals. I will look for "Made In Canada" on the block
J
johnernst
Last Name: Ernst
Post by johnernst » Thu Apr 27, 2023 8:57 pm
Steve Bruce McCalley does mention in his book
"Generally all Canadian engine numbers begin with "C" but some exceptions seem to appear, with "HC" and "SC" being noted, as well as some without any letter.
But perhaps it is a replacement engine, not sure,
J
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Apr 27, 2023 9:08 pm
The block has Made in Canada on it. See the carb thread photo.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Fri Apr 28, 2023 10:21 am
What I see is a double stamp. Very common with hand held stamps. The “shadow stamp” being a poor first hit or a bounce. To me the double spacing and characters all match.
BUSHMIKE
Last Name: Cushway
Post by BUSHMIKE » Fri Apr 28, 2023 10:22 am
BEAUTIFUL TT John!
John Codman
Last Name: Codman
Post by John Codman » Fri Apr 28, 2023 2:07 pm
I agree with Bushmike. It is a beautiful T. On my '27 the frame number is accessible by removing the floorboards The number is stamped on the top frame rail just ahead of the right door opening. I am however, assuming that this would be the same for Canadian T's.
