Axle Housing Revits
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Axle Housing Revits
Post by Plankhill » Sat Apr 29, 2023 5:08 pm
What size are the rivets that attach the rear axle tube to the pumpkin?
Re: Axle Housing Revits
Post by Rich Eagle » Sat Apr 29, 2023 6:01 pm
Here is a discussion that might help.
https://www.mtfca.com/discus/messages/5 ... 1428020838
Allen B uses 1/4" unf bolts. I have used 1/4 " bolts too. I don't remember having to drill the holes.
I'll keep looking for something more helpful.
Post by Allan » Sat Apr 29, 2023 8:39 pm
Brendan, what year of axle is it that you are working on? Answers will vary accordingly.
Plankhill
First Name: Brendan
Last Name: Doughty
Post by Plankhill » Sun Apr 30, 2023 5:51 am
Allen. It’s a 21 to 25 type. It’s a shortened housing with a Ruckstell center that I want to convert back to a standard length unit.
Shortening housings to make snowmobiles was common around here.
Post by Allan » Sun Apr 30, 2023 11:36 pm
OK then. My bolt method is for fixing the early housings which had the flare on the inside end riveted to the housing. Your will have straight tubes between the backing plate and the centre housing. I have replaced some loose rivets in those. I drilled out one rivet to find the size and bought replacements. These were fitted with the round head on the inside, and held in place with a heavy tapered buck, while they were heated on the outside end and that was formed. I did them one at a time.
Plankhill
First Name: Brendan
Last Name: Doughty
Post by Plankhill » Mon May 01, 2023 6:01 am
Thanks Allan. A tapered buck is the only way I can see to do it also.
