Floor blueprint
FULLBORE
Topic author - Posts: 35
- First Name: Mike
- Last Name: Coats
Floor blueprint
Is there a website with a drawing of a model t floor. I need the location and diameter of the starter switch hole.
- Last Name: House
Re: Floor blueprint
What model year ? What body style ?
FULLBORE
- First Name: Mike
- Last Name: Coats
Re: Floor blueprint
1927 touring.
Been Here Before
- First Name: George John
- Last Name: Drobnock
Been Here Before
Moxie26
- Last Name: Jablonski
Re: Floor blueprint
George.. that drawing may be reference to a 26-27 four-door sedan or a TT truck since it shows the gas tank under the front seat. He has a 27 touring car.
FULLBORE
- First Name: Mike
- Last Name: Coats
Re: Floor blueprint
Thanks for the drawings, but I don’t believe they show the hole for the starter switch.
I’m actually looking for the starter switch hole diameter and location
- Last Name: Humble
Re: Floor blueprint
Mike,
Dont have the drawing. You can get one from the Benson Ford Research Center, its complicated and costs money. If this helps, decades ago my father made new a floorboard using the original as a template, I cannot vouch for its accuracy. The hole is 1 3/8" dia, and all measurements are perpendicular to the edge of the floorboard.
FULLBORE
- First Name: Mike
- Last Name: Coats
Re: Floor blueprint
That is exactly what I need.
Re: Floor blueprint
Why not just map the position of the starter button and drill the floorboard to suit? At least that way any differences between cars will be negated and your drilled hole will be concentric to your particular starter button.
