TT Rearview Mirror
BUSHMIKE
Topic author - Posts: 354
- First Name: Mike
- Last Name: Cushway
- * REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
TT Rearview Mirror
Very few pics on the web of TT’s with mirrors. I would like to mount a drivers side mirror and have had no luck finding one. I like the looks of the hinge mounted brackets but dont like the brace going to the door panel. I have a couple of the extendable stalk type mirrors and can easily fab a “period looking” bracket. I would like to try to find an original first. Anyone have one for pics or possibly for sale?
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: TT Rearview Mirror
We perused eBay and other sites for a "look" we thought would compliment the design/age of the TT. CAUTION: The best looking mirrors have severe lack of extension. Meaning, I am NOT able to see traffic behind the truck. Being as our TT is a C-cab, the windshield is not attached to the roof. I purchased a open car rear view, windshield mount, mirror. I have not mounted it yet but I am sure I will be able to see through the oval back window providing a direct view behind the TT. The two short side mirrors will give good view of both sides.
I recommend having someone hold a mirror about where you would like it to be. Look through the mirror to see if you achieve the results you require. Move in/out, up/down to find the approximate arm length, size, and mounting position that works for you. Then find a mirror you like that will meet those measurements.
Good Luck
Good Luck
If your TT has a wide and high bed (think grain) you will need mirrors that stick out far enough to to see past it.
mike catlin
- Last Name: Catlin
- * REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
Check Snyder's
Nate22huckster
- First Name: Nathan
- Last Name: Fahrni
- * REQUIRED* Type and Year of Model Ts owned: 1922 huckster, 1925 tudor, 1926 TT dump truck, 1927 tudor
I was lucky enough to acquire an original one for my TT recently. They are very rare from what I understand. Hopefully this is helpful.
Nate22huckster
- Last Name: Fahrni
Here’s some pictures with it in place on the truck
BUSHMIKE
- First Name: Mike
Nathan,
Thanks a million for responding and making such a nice complete drawing! Now, my question is what keeps the assembly in location? I see its mounted on the door hinge ears but I would think clamping it with the hinge pin would tighten the door hinge too much? Is it functional on your truck?
BUSHMIKE
- First Name: Mike
Nathan,
On closer examination of the pics, I see the locking setscrew in the hinge bracket. Is it pointed to dig into the hinge ear?
Rod Petrie
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
My 26TT had the bracket but no mirror. I bought a mirror from one of the vendors and I can see traffic behind me just fine. After cleaning everything up the bracket wanted to vibrate out too much so I added a small piece of tin to keep it from doing so.
Rod Petrie
- First Name: Rod
- Last Name: Petrie
Nate22huckster
- Last Name: Fahrni
Mike, yes there are two drilled and tapped holes for set screws about 1-1/2” apart, they line up with the door tabs to keep the mirror bracket positioned to the door.
StevenS
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Here is what I did for mirrors on my TT.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
BUSHMIKE
- First Name: Mike
Thank you all for input on mirrors. I found and purchased a set of NOS mirror stalks on EBay that, after confirming some dimensions with the seller, looked like they would work. They arrive today and a quick preliminary fit-up looks like they should work perfectly. They mount on the hinge and have a locking setscrew which I will detent into the appropriate hinge “ear”. The distance between ears is 2” as is the TT hinge. Anyone recognize these as to era or application? Ill get a couple pics after mounting them. They will work until I either find or make a set of originals.
