Sure Fire Ignition 6 and 12 volt??
My1914T
First Name: Ross
Last Name: Benedict
* REQUIRED* Type and Year of Model Ts owned: 1920 Drs. Coupe
Post by My1914T » Wed May 10, 2023 3:37 pm
We are dealing with an estate T that has a Sure Fire ignition. The literature I have says 12 volt only, but owner says NO, 6 VOLT!!
Did they ever come for 6 volt??
Thanks for any information one way or another.
Ross
Re: Sure Fire Ignition 6 and 12 volt??
Post by Scott_Conger » Wed May 10, 2023 3:54 pm
I am guessing you mean "True-Fire" (?) and if so, then yes, folks run them on 6V, but the ones who have tried otherwise say it runs better on 12V
Hope this is helpful
If you purchase and find it doesn't work, you can do some searches on the Forum for help (I think they are no longer made and support is where you find it)...though I may be wrong.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Wed May 10, 2023 3:59 pm
“True-Fire”. I believe that’s what you’re asking about. It runs on any voltage from 6 to 12.
William L Vanderburg
1922 Center Door Sedan
Post by TRDxB2 » Wed May 10, 2023 6:09 pm
Thought about it long ago & so I copied the instructions
Congratulations on your purchase of the Bittner Engineering True-Fire Ignition
System. This Ignition System is designed to operate on any voltage between 6
and 12 VDC and replaces the original commutator and coils on your Model T Ford
TRUE FIRE Instrctions.pdf
(612.51 KiB) Downloaded 81 times
My1914T
First Name: Ross
Last Name: Benedict
Post by My1914T » Wed May 10, 2023 8:10 pm
True-Fire March 2004.pdf
(3.49 MiB) Downloaded 77 times
Yes TRUE-FIRE, my error!!
I have a version of the instructions (that maybe from a later manufactuerd dated "Revised March, 2004." indication 12 volt only. (See attached) The extra unit has a"IGBT 60-12 V" on the bootom, I'll have to go to actual T and see what's there (if anything) fingers crossed.
Thanks for all the imput.
Ross
Last Name: Wrenn
Post by TWrenn » Wed May 10, 2023 8:50 pm
Trouble with the T.F. is as far as I know, Mr. Bittner is no longer dealing with it and there goes the support system for it.
Back when I had my first T.F. on my very first T (came with it...no mag) I found out that you really need to "dissasemble" it per all the connections and thorougly clean them, seems grit and grime that makes its way to the contacts makes it not happy. An hour well spent about every other year. My current '11 Torpedo also came with T.F. (oh the shame of it all! :lol: ) but it does start and run fantastic with it. Going into year 3 now, time to clean up its act! I may put the system back to all stock someday though, as I have "corrected" a few other "no-no's" on this car...ha ha.
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Post by FordFool » Wed May 10, 2023 9:12 pm
I have ran TF ignition in three cars for 16 years. No problems at all. 8 and 12 volt systems run like a dream 😊
Post by TRDxB2 » Wed May 10, 2023 10:22 pm
True-Fire March 2004.pdfYes TRUE-FIRE, my error!!
Ross
The revision dates on the two instructions are just 1 Month apart and the commutator parts are different. It is possible that the electronic components initially used were no longer available - hence the changes. Regardless of what model? you will need the small puck like piece (clear or white) for the commutator. A member made a few last year I believe
This is from MAC's web site (out of stock) https://www.macsautoparts.com/model-t-t ... 617-1.html
-- Trying to see if there were 2 versions
frontyboy
First Name: dick
Last Name: dock
* REQUIRED* Type and Year of Model Ts owned: T sprint cars
Post by frontyboy » Wed May 10, 2023 10:48 pm
I have run Tru Fire systems for many years. The issue with the original systems was not the system but the material the rotor was made of. It tended to melt with higher engine temps.
A member here Walt Berdan had made new rotors out of a different material and they hold up under higher temps. When the older rotors got hot the pressed in magnets dislodged and cause mis fires and also quit providing spark.
I found Mr Bittner very helpful and he even repaired a couple of Tru Sparks I bought here . I as a precaution carry an extra box and timer with a harness attached just incase but have never needed it.
It is very important to connect the system as directions spell out. If you don't it only take a second to destroy the circuit board inside the coil box. I run mine on 12 volts very quick to start and runs very smooth even under heavy load.
As a disclaimer, all you authentic and original model t folks here don't waist my time telling me what a bad model t owner I am, because at 80 years old I really don't give a damn about your opinon
My1914T
First Name: Ross
Last Name: Benedict
Post by My1914T » Thu May 11, 2023 2:08 am
I had bought the white rotor from Walter some time ago, as i saw the need for it in the spare True-Fire our friend has.
I, as well, am 80, and feel somewhat as you.
Thanks everyone, the"village" has proved it's worth, yet again!
Ross.
