Ignition switch panel
Mel King
Topic author - Posts: 96
- First Name: Melvin
- Last Name: King
When did the switch changed from 4 rivit to 2 rivit ?
MEL
Re: Ignition switch panel
Pretty early on I'd guess, probably sometime in 19 or 20. You have to consider too that at least three or four companies made them, and they didn't all do their riveting the same way.
SurveyKing
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- Board Member Since: 2014
To piggy back on the initial question here, does anyone know if the lettering on the switch plate was painted white? I have seen them both ways.
Originals show paint in the stamped metal lettering.
1919 from illustration 1926 non-starter 1919 with large nickel handle
