Upper Center Main Bearing
Vrayfoster
Topic author - Posts: 72
- First Name: Victor
- Last Name: Foster
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
- Board Member Since: 2002
Does anyone know what engine number Ford started putting in the upper center main bearing?
Re: Upper Center Main Bearing
All the upper mains in the block were left unbabbitted not just the center. Starting around engine No.38,263 Feb 14th. 1911 some were babbitted with enclosed valve chamber then around 46,236, all engines had the upper babbitt and enclosed valve chamber.
Vrayfoster
- Last Name: Foster
Thanks for the info. I just bought a '10, and I wondered if this engine was one with the upper center main without Babbit.
