Broken Crank Club
Rod
First Name: Rod
Last Name: Barrett
* REQUIRED* Type and Year of Model Ts owned: 1909 Two Pedal Touring, 1910 Wide Track Tourabout, 1912 Towncar, 1912 Touring, 1913 Touring, 1924 Depot Hack, 1925 Front Wheel Drive Speedster
Board Member Since: 2014
Broken Crank Club
Post by Rod » Fri Jun 02, 2023 7:37 pm
Well it finally happened to me. During the Thursday tour at the MTFCA, I broke a crank on my 24 Depot Hack. We were on the return trip from the Carillon Historical Park and about 10 miles from the MTFCA Museum when it happened. A loud knocking from the engine and we pulled over. A few minutes later, here comes Jerry Kramer to the rescue. He was only a few miles from his house. He drove his T there and returned with a truck and trailer. THANK YOU JERRY!
Fortunately, I have been saving a SCAT crank at the house in case this ever happened. I will pull the engine and take it to Ron's Machine Shop to get in the que for a total rebuild.
Rod
Gracie'sDad
Last Name: Dow
Re: Broken Crank Club
Post by Gracie'sDad » Fri Jun 02, 2023 9:07 pm
Admission into the brotherhood is testament to the fact that you have finally arrived. I joined 3 years ago and am better for it. Welcome my friend, we have been waiting for you.
KeithG
First Name: Keith
Last Name: Gumbinger
Post by KeithG » Fri Jun 02, 2023 9:12 pm
Sad of course, but it could have been worse.
Cheers,
Keith
Model T Mark
Last Name: Eyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring 1914 Touring and Roadster 1915 Touring 1926 Roadster
Post by Model T Mark » Fri Jun 02, 2023 9:16 pm
I joined 22 years ago, not fun! Hang in there!
Post by Allan » Fri Jun 02, 2023 9:50 pm
I joined the club 4 years ago, after almost 50 years of T driving. Keith said it could have been worse! My son had the block destroyed when he had a break. Cross your fingers that you don't have the same.
Hoping for the best.
Racer_22
First Name: Kevin
Last Name: Prus
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
Board Member Since: 2004
Post by Racer_22 » Fri Jun 02, 2023 10:32 pm
I will have a new Skat T crank at the Homecoming swap meet in the morning.
Kevin Prus
Racer_22
First Name: Kevin
Last Name: Prus
Post by Racer_22 » Fri Jun 02, 2023 10:40 pm
Also have a new 290 cam at the homecoming swap meet
Fire_chief
First Name: Charlie
Last Name: Gagel
Post by Fire_chief » Sat Jun 03, 2023 6:40 am
It's a tough club to join, but I achieved my membership many years ago. I then renewed that membership. The solution was to use Scat cranks in my rebuilds, as can be attested to Kevin. I now keep a few Scats on hand, for myself or close friends.
Last Name: House
Post by George House » Sat Jun 03, 2023 8:01 am
Yep… happened to me too back in ‘76 on the Glidden Tour in Colorado. I determined the cause at the time. Do you have any idea as to the ‘why’?… I feel your pain 😞
BHarper
First Name: Bill
Last Name: Harper
* REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Post by BHarper » Sat Jun 03, 2023 8:58 am
Hello Rod,
My condolences for your misfortune. You were wise to put aside a Scat crankshaft for the day which you knew would come as they can be on a months long backlog.
I am a two time member of the club. 🙄
Bill Harper
Keene, New Hampshire
Post by Norman Kling » Sat Jun 03, 2023 10:19 am
Sad! This is one of he weak points of the Model T. My grandfather told of that happening back in 1926 with a car only a couple years ago. Happened on a cross country trip. The car was towed into a Ford dealer and fixed overnight. Now I don't think a Ford dealer would even know much about Model T's.
Sorry for your problem.
Aussie16
First Name: Warwick
Last Name: Landy
Post by Aussie16 » Sun Jun 04, 2023 7:43 am
Look on the bright side. If you have broken one, It means you have also had the pleasure of driving your T. I drove for 25 years, numerous T's and many thousands of miles before it finally happened to me! Wouldn't trade those miles for anything! Also have learned a lot about how not to drive and also how to preserve the life of a crank. I think many breakages are a result of poor driving habits, poor set up and just plain old worn out motors. Well sorted and rebuilt to proper specs will surely reduce the chances of a breakage.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sun Jun 04, 2023 8:21 am
Question: I’m in N.J. Exactly where would I have to ship my block for babbit replacement and what would the approximate cost be including one of the later cranks?
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sun Jun 04, 2023 12:40 pm
Charlie.... Our local babbitt machine shop is in Strasburg Pennsylvania .,..... Schwalms Babbitted Bearings , still run by Ora Landis. ... www.schwalms.com. ..... This shop did our engine over 20 years ago..., His shop is just down the hill on Georgetown road a little bit south of the railroad Museum.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Post by Charlie B in N.J. » Sun Jun 04, 2023 12:49 pm
Close enough to haul myself. Cool.
Moxie26
Post by Moxie26 » Sun Jun 04, 2023 12:53 pm
We did the same, and the trip wasn't that bad.., Ora's father passed last month.
