Good Afternoon,
Attached are the amended Model T 500 results as there were some input errors on Day 3.
Congratulations to MTFCA Past President Larry Azevedo on his win!
Todd Wheeler
Montana 500 Final Results
- First Name: craig
- Last Name: leach
Re: Montana 500 Final Results
Congratulations Larry. Job well done. That was close be NASCAR standards.
KirkieP
- First Name: Kirk
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
Thanks for posting.
I thoroughly enjoyed myself.
Congratulations to Larry.
Thanks ever so much to all the people who made this event possible. It is a lot of Work.
Kirk Peterson
Santa Fe NM
Santa Fe NM
MT5Tony
- First Name: Tony
- Last Name: Cerovski
- * REQUIRED* Type and Year of Model Ts owned: Six 1926-7 Roadsters, One 1925 cutoff, & One-27-Coupe
Here is Day one, Leg-1, Leg-2, Leg-3, & Leg1>3 Summary Sorted.
MT5Tony
- First Name: Tony
Here are Day 2, Leg-4, Leg-5, Leg-6, Leg-7, & Legs 1>7 Summary.
MT5Tony
- First Name: Tony
Here are Day 3 results, Leg 8, Leg-9, and Legs 1-9 Summary and final standings.
The tear down went exceptionally well this year. Very Cordial.
Larry had a 'non-script' (1927 style) Ford Model T high head on his engine. The directors called his in-place head ok, but he must use Ford script motor head next year. Larry is also a director.
Larry had carried his 6-volt optima battery in the trunk of his roadster. Larry was missing a battery carrier bracket below the turtle deck. He agreed to install and use a standard battery carrier bracket with his battery in it for the next and subsequent years.
One of Larry's combustion chambers was 270 cc's, which is ok. The other chambers were slightly higher.
1. Congratulations to Larry Azevedo of New Mexico for winning the 2023 Montana 500!
2. Congratulations to Dan Brown of Iowa for taking second place with a time of just 14 seconds slower than Larry.
3. Congratulations to Eddie Wright of Colby, Kansas for taking third place with a time of 3 minutes and 11 seconds slower than Larry.
