switch and ammeter wiring
makenstuff
First Name: Brian
Last Name: Potter
* REQUIRED* Type and Year of Model Ts owned: 1926 TT
Post by makenstuff » Tue Jun 27, 2023 9:31 pm
I'm preparing to rewire this 26 TT. The existing wiring is a bit of a conundrum. Let's start with the ammeter to switch panel. all the diagrams I've seen have the battery wire directly to the ammeter, then jumped to the switch, then back out to the car. (Solid Yellow to ammeter, Yellow black jumper to switch, Yellow black to wiring block on firewall). The existing wire has the jumper from ammeter to switch, but both hot wires directly to one side of the ammeter. The post looks to be designed for this purpose. Should I rewire per all of the diagrams and ignore this anomaly?
Re: switch and ammeter wiring
Post by TRDxB2 » Tue Jun 27, 2023 10:02 pm
If you get a repro wire harness it may force you to wire in the normal,position because of the wire length. But your current wiring - makes no difference which end of the "jumper wire" you connect to.
Post by John kuehn » Tue Jun 27, 2023 10:11 pm
Some of the new repo wiring sets may have slightly different color wires than the original wiring so be sure to use the correct wiring diagram when you’re rewiring your car.
Hopefully the new repos are now pretty much correct as one I used wasn’t exactly all correct as far as the color went. It came down to following a diagram to get it right by the process of elimination as the different colored wire was the only one that would be correct for the terminal screw.
makenstuff
First Name: Brian
Last Name: Potter
Post by makenstuff » Tue Jun 27, 2023 10:52 pm
Thanks. So to be clear, on my existing ammeter, on one post, (the left post in the rotated photo), the ammeter is connected to the switch and the generator, the other post is connected to the battery.
My new harness is color coded like this. So, I'll just rewire to match these diagrams.
Post by Steve Jelf » Tue Jun 27, 2023 11:36 pm
This shows correct wiring, colors, and wire sizes.
Last Name: Juhl
Post by Oldav8tor » Wed Jun 28, 2023 10:07 am
There is a difference between the photo and the diagram. In the Photo, the "bright" headlight wire goes to 5 on the terminal strip and the "Dim" to 6. On the diagram those two wires are reversed. Not a big deal but confusing.
This drawing appears to be old but I don't know it's source. It shows the "Bright" on 6 and "dim" on 5 like in Ron's drawing. Either way you'd be OK as long as you followed thru with connecting the switch Bright/Dim to the same posts as the headlight's Bright / Dim.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Wed Jun 28, 2023 10:33 am
Post by Jerry VanOoteghem » Wed Jun 28, 2023 11:12 am
Your current wiring is a mess. I would completely remove it and ignore everything about it. Install the new harness according to the wiring diagrams posted above. To do any less, would be repeating past errors and "work arounds". Also, forgive me if you already know this, but T's have a negative ground. I only mention it because maybe the person who installed your current wiring may not have known it.
Last Name: Hjortnaes
Post by DHort » Wed Jun 28, 2023 11:36 am
www.texastparts.com
Go to free downloads
Print out your wiring diagram from there
Same as what Steve shows above
makenstuff
First Name: Brian
Last Name: Potter
Post by makenstuff » Wed Jun 28, 2023 12:04 pm
That is the plan. Right now, the car runs and drives on battery only. I don't know if the magneto works. The lights don't work. The windshield wiper does though ;) The current wiring has so many splices, frayed spots, and colors, that replacing it seemed like the best place to start. Considering that it runs, my only hesitation is that it won't after I rewire it. It looks fairly simple. I just balked when I saw more wires coming from the ammeter than any diagram that I had seen.
Thanks for everyone's help!
Post by TRDxB2 » Wed Jun 28, 2023 1:31 pm
Diagrams for a '26
