switch and ammeter wiring
makenstuff
Topic author - Posts: 6
- First Name: Brian
- Last Name: Potter
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
I'm preparing to rewire this 26 TT. The existing wiring is a bit of a conundrum. Let's start with the ammeter to switch panel. all the diagrams I've seen have the battery wire directly to the ammeter, then jumped to the switch, then back out to the car. (Solid Yellow to ammeter, Yellow black jumper to switch, Yellow black to wiring block on firewall). The existing wire has the jumper from ammeter to switch, but both hot wires directly to one side of the ammeter. The post looks to be designed for this purpose. Should I rewire per all of the diagrams and ignore this anomaly?
Re: switch and ammeter wiring
If you get a repro wire harness it may force you to wire in the normal,position because of the wire length. But your current wiring - makes no difference which end of the "jumper wire" you connect to.
Some of the new repo wiring sets may have slightly different color wires than the original wiring so be sure to use the correct wiring diagram when you’re rewiring your car.
Hopefully the new repos are now pretty much correct as one I used wasn’t exactly all correct as far as the color went. It came down to following a diagram to get it right by the process of elimination as the different colored wire was the only one that would be correct for the terminal screw.
makenstuff
- First Name: Brian
- Last Name: Potter
Thanks. So to be clear, on my existing ammeter, on one post, (the left post in the rotated photo), the ammeter is connected to the switch and the generator, the other post is connected to the battery.
My new harness is color coded like this. So, I'll just rewire to match these diagrams.
This shows correct wiring, colors, and wire sizes.
- Last Name: Juhl
There is a difference between the photo and the diagram. In the Photo, the "bright" headlight wire goes to 5 on the terminal strip and the "Dim" to 6. On the diagram those two wires are reversed. Not a big deal but confusing.
This drawing appears to be old but I don't know it's source. It shows the "Bright" on 6 and "dim" on 5 like in Ron's drawing. Either way you'd be OK as long as you followed thru with connecting the switch Bright/Dim to the same posts as the headlight's Bright / Dim.
Been Here Before
- First Name: George John
- Last Name: Drobnock
Your current wiring is a mess. I would completely remove it and ignore everything about it. Install the new harness according to the wiring diagrams posted above. To do any less, would be repeating past errors and "work arounds". Also, forgive me if you already know this, but T's have a negative ground. I only mention it because maybe the person who installed your current wiring may not have known it.
- Last Name: Hjortnaes
www.texastparts.com
Go to free downloads
Print out your wiring diagram from there
Same as what Steve shows above
makenstuff
- First Name: Brian
- Last Name: Potter
That is the plan. Right now, the car runs and drives on battery only. I don't know if the magneto works. The lights don't work. The windshield wiper does thoughJerry VanOoteghem wrote: ↑Wed Jun 28, 2023 11:12 amYour current wiring is a mess. I would completely remove it and ignore everything about it. Install the new harness according to the wiring diagrams posted above. To do any less, would be repeating past errors and "work arounds". Also, forgive me if you already know this, but T's have a negative ground. I only mention it because maybe the person who installed your current wiring may not have known it.
Thanks for everyone's help!
Diagrams for a '26
