Length Simmons spray needle valve
Post by Mark Gregush » Thu May 16, 2019 9:03 pm
Anyone know the correct length of the spray needle valve for the Simmons type carburetor? Need to trim back a NH needle to use.
V4F
First Name: Justin
Last Name: Dalke
Re: Length Simmons spray needle valve
Post by V4F » Fri May 17, 2019 12:31 am
Also notice the small difference in the brass rod below the threads.
It probably doesn't matter much, but something to keep in mind.
Post by Mark Gregush » Fri May 17, 2019 12:43 am
Thank you! Don't know if the little bit of brass will be an issue, but as it is part of the crimp that keep the parts together I think I will leave it.
