Model A horn.
Topic author - Posts: 162
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Model A horn.
Will a Model A horn work with a negative ground or will it need to be isolated and hooked up factory?
Re: Model A horn.
Either polarity will work, that A motor aoogha horn is series wound DC motor, won't make a difference on the polarity of the DC current.
- First Name: Sean
Re: Model A horn.
Thanks Dan.
- First Name: Luke
- Last Name: P
Re: Model A horn.
Mine works fine, -ve ground and 12V (yes, I'm poking someone in the ribs
Luke
Luke
