Hercules Model C
Keith Daniels
First Name: Keith
Last Name: Daniels
* REQUIRED* Type and Year of Model Ts owned: 1927 TT Truck, 1926 Touring
Hercules Model C
Post by Keith Daniels » Sat Jul 08, 2023 10:26 pm
Picked one up at an antique store today, listed as a tire stretcher. I just got done going through past threads, at $22.50 I think I did pretty good.
It appears to be original paint, and what I read tends to agree. A little oil and I think we are good to go!
Distagon2
Re: Hercules Model C
Post by Distagon2 » Sun Jul 09, 2023 7:39 am
You got a great deal. That tool makes tire work on split rims a piece of cake.
Last Name: House
Post by George House » Sun Jul 09, 2023 8:44 am
Good score. But that tool has ruined a whole lot of split rims when operators don’t follow instructions in its use.
BUSHMIKE
Last Name: Cushway
* REQUIRED* Type and Year of Model Ts owned: 1925 TT, 1926 TT, 1926 TT
Post by BUSHMIKE » Mon Jul 10, 2023 8:54 am
Where do I find proper instructions for its use?
Post by TRDxB2 » Mon Jul 10, 2023 9:20 am
These are general instructions I found
The red Y is to put the rim back in place (from a previous discussion)
Post by DanTreace » Mon Jul 10, 2023 9:22 am
Here is one set of instructions, similar tool.
Last Name: House
Post by George House » Mon Jul 10, 2023 12:47 pm
Good save Frank. Those are the instructions I posted last year..😁
Keith Daniels
First Name: Keith
Last Name: Daniels
Post by Keith Daniels » Mon Jul 10, 2023 9:57 pm
So basically you push apart with the screw leg just off to the solid side of the tab, then to pull together you flip it so the screw hook is directly across from the split, and the two legs are equal distance from the split?
