Tire pump
Will_Vanderburg
Topic author - Posts: 944
- First Name: William
- Last Name: Vanderburg
Tire pump
Spent some time refurbishing my tire pump. Cylinder all smooth and shiny.
Forgive the modern hose clamps. I cleaned the hose to tube connection. It was clogged tight. It pumps air and does inflate a bicycle tube. There’s no ball bearing in it. And I didn’t remove the valve plunger.
What color should the base be? Right now it’s red oxide.
William L Vanderburg
1922 Center Door Sedan
Re: Tire pump
Don't bet the farm on this, but I think all black would be correct. I left the tube polished brass, but I think it's incorrect. My version of "natural" wheels.
I was pleasantly surprised to find that the local Ace Hardware had the old style compression clamps you loosen with pliers to install.
These pumps were made without a check valve and with a chuck that had no center post, relying on the tube's stem valve to keep the pressure in the tire. I don't understand how your pump can work with a center post in the chuck.
Will_Vanderburg
Re: Tire pump
There’s a tiny hole in the side of the center post of the chuck
Will_Vanderburg
Re: Tire pump
Steve,
Can you post a pic of the clamps you speak of?
Re: Tire pump
At the pump end of the hose is a clamp from the hardware store.
At the other end I have twisted baling wire. I'm not sure why. I probably broke the real clamp trying to install it.
Will_Vanderburg
Re: Tire pump
When I removed my chuck to clean it, it was secured with wire as well.Steve Jelf wrote: ↑Tue Jul 04, 2023 4:24 pmIMG_0328 copy.JPG
Re: Tire pump
The standard Ford repair kit.
Will_Vanderburg
Re: Tire pump
I took the pump again and tried to pump up a hand truck tire. It does pump it up, but I do notice there is some air being sucked back out of the tire. A small amount.
There was no ball bearing in the pump but the chuck does have the center post. I’m going to get a bearing and see if that stops the leakage.
I really don’t want to destroy an original chuck. I do know chucks are available without the center post. Maybe I’ll try that.
Re: Tire pump
As Steve said, the centre post is there to depress the valve core centre to allow air to enter. While it is depressed any air pumped in is free to escape.
You need to either remove the centre stem in the chuck, or fit a non return valve at the pump end of the hose.
Re: Tire pump
Yes, I found them online pretty easily.
Re: Tire pump
I believe the tire pump would be more efficient with a check valve at the pump end of the hose. That way, you would not lose the small volume of compressed air in the hose with every stroke.
