What timer do you use
mjr
First Name: MARSHAL
Last Name: REYSEN
* REQUIRED* Type and Year of Model Ts owned: 1925 touring 1926 Dr. coupe
Post by mjr » Fri May 17, 2019 9:16 am
I put a New Day in and was not happy with it.
Robert Bente
Last Name: Bente
* REQUIRED* Type and Year of Model Ts owned: 1916 runabout, 1921 touring, 1915 touring
Re: What timer do you use
Post by Robert Bente » Fri May 17, 2019 9:29 am
Marshal, sometimes it’s not the one component, but a combination of many. You didn’t sate why your dissatisfied.
I also put a New Day timer on my runabout, and was very pleased with the results. This was after I also replaced the spark plugs and plug leads, new wiring harness and had my coils rebuilt. It will go 45 mph if I feel daring.
r/s Bob
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Fri May 17, 2019 9:43 am
I use the New Day timer. They dont like oil inside. I installed a moderd seal and cleaning now is minimal.
Post by Mark Gregush » Fri May 17, 2019 10:02 am
What condition are the engine, coils, fuel systems in? Not enough information about why there seem to be issues. I and others that use them seem to be happy with the New Day. No timer in the world will help if the coils are out of wack or if compression is too low.
Post by Original Smith » Fri May 17, 2019 10:15 am
I've been using New Days for years on every Model T I own. If you are not happy with it, you are doing something wrong. Perhaps you purchased a reproduction from long ago, which were no good.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri May 17, 2019 10:47 am
Over 50 years ago, a New Day timer ended all of the troublesome issues I had with the stock Ford timer. As Larry points out, there's a record of bad repro New Days, but good reports on the latest ones being made. Currently I'm running the TW that came on my T when I bought it, I re-faced the contact race and put in a new brush. I've had no trouble with it, but when it finally wears out, I will replace it with a New Day. Please give us a little more detail on your problems so we can help. How was the car running before you replaced the timer ? Is your New Day an original or a repro ? If a repro, when and where purchased ? There have been issues with cobbled up or re-fitted brushes. Pictures of your New Day timer and brush may also help. Good luck !! None of us like to see a Model T "pull up lame" if we can help.
"Get a horse !"
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Post by fbergski » Fri May 17, 2019 12:14 pm
My 11 has a roller and my 16 has a i-timer.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri May 17, 2019 12:25 pm
Back in the ‘70’s I put a BEST brand timer in my 27 roadster. They are white plastic of some sort. I’ve “trued” it at least once in the lathe, but it is still going strong after probably at least 15,000 miles. I should have bought a spare!!
One of the key things with any timer is having the front cover correctly centered. And, as stated, brush type timers don’t like oil!!
On my 13 I’m using a “trufire” after realizing that the Hienz coils never were any good and I was embarking on a 2500 mile trip.
Post by Rich Eagle » Fri May 17, 2019 12:34 pm
I have used 2 dozen roller timers both used and reproduction with just oil for the last 50 years on 7 different cars. Yes, there is probably a better way.
Post by DanTreace » Fri May 17, 2019 1:32 pm
Anderson flapper timer, best all year touring timer, with no daily or weekly maintenance, just annual inspection.
But... :D for my '27 touring, which is the wife's favorite for tours, the I-Timer, it's ideal.
Post by John kuehn » Fri May 17, 2019 1:58 pm
Any of the three timers, New Day, Anderson or a good roller timer will run fine on a T IF your cars electrical system is ok. Nothing beats a rebuilt coil box and new wiring. If those 2 components has an issue a new timer won’t fix it.
I have 3 T’s. 2 with New Days and the other T with an Anderson. They are working fine. How good are your coils. That’s another component that has to be in good shape for a good running T.
Since you replaced the timer was your T having an issue before you did?
Last Name: Wrenn
Post by TWrenn » Fri May 17, 2019 2:20 pm
I agree with John Kuehn...nothing beats a good timer box. I bet over half of T owners need 'em rebuilt and they don't even know it. Get the FunProjects rebuild kit, I think all the vendors sell it. Worth every penny. Then make sure your coils are
in proper condition too. I have a New Day (not the "S" junk repop) on my '25 and it's doing good. Been running the TW timer on my '13 ever since I got the car, and still love it. Just keep it clean, usually once or maybe twice a year, depending on how much you drive of course. Neither one likes oil, but the TW tends to be a bit more susceptible to it.
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Fri May 17, 2019 7:32 pm
Been work on Ts 35+ years never heard of a timer box?
Had great service from Anderson and the New Day although for a period new days where JUNK but seems tobe corrected now
Anderson only requires little contact lube each year and ND only a wipe out to clean
Most people issues is not the time but coil box and cheap / soft contacts and give them a clean and make sure they are tight and sing each year at inspection/servicing time
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Fri May 17, 2019 7:48 pm
I have used New Day on all T's I have had and am now down to two. I spend some time at places like Hershey to look for the old style timer cap and have replaced the brush on several. I keep spares but never have used them. Probable need to sell some before someone calls me a "hoarder".
Nv Bob
First Name: Bob
Post by Nv Bob » Fri May 17, 2019 10:13 pm
Hoarder
I could use a spare if that day ever comes
Last Name: Wrenn
Post by TWrenn » Fri May 17, 2019 10:29 pm
Oh geez! Thanks NvBob! I bet you knew I meant COIL box!! ..sometimes I dont know where my mind is!! Thanks for ur remark!! LOL..some days....well you know!
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sat May 18, 2019 8:11 am
I use an E-Timer. Prior to that was a TW timer, and two Andersons before that. The first Anderson was actually very good, but after ten years it wore out, and the quality seemed to have dropped when I bought another one. Not that having to maintain the various parts of the car is a problem, but the E-Timer's consistent timing and complete absence of mechanical wear, plus the improvement in driving performance is what sold it on me.
Post by Steve Jelf » Sat May 18, 2019 2:17 pm
New Day works for me. I do use a carbon brush instead of bronze. It's cut from a generator brush.
Mountainrider
First Name: Neil
Last Name: Haywood
* REQUIRED* Type and Year of Model Ts owned: 1915 roadster
Post by Mountainrider » Sat May 18, 2019 3:45 pm
I run a TW and love it. Had a bad repo New Day that never ran consistent. Now have a original with a brush I modified with a better spring. Runs as well as the TW.
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Sat May 18, 2019 6:56 pm
I'm in the TW camp as well. Just take it off and blow the little bit of carbon dust out of there once a year. Been four year of great service out of it and I have yet to experience a problem with it. Just have to remember to keep that little wire that keeps the brush in its holder so you can install the timer cover.
Charles J
First Name: Charles
Last Name: Jenkins
* REQUIRED* Type and Year of Model Ts owned: Coupe
Post by Charles J » Sat May 18, 2019 10:49 pm
Tiger you see nos ones from time to time
Jugster
First Name: Bob
Last Name: Coiro
Board Member Since: 2009
Post by Jugster » Sun May 19, 2019 12:11 am
For a good many of us, the experience of driving a century-old car design isn't about convenience or reliability. Historical purists see frequently required maintenance and inconvenient breakdowns as part of the game. Others are just looking for fun and in a sense, they are purists, too—just of a different kind. They're okay with Volkswagen distributors and feel the same about putting demountable wheels on a pre-1919 Model T. Those things certainly improve the reliability of the car and if you're going to do a lot of touring, reliability counts for a lot.
I'm not a devout purist. For safety reasons, my car has three rear-view mirrors, extra stop-lamps, 4-way flashers, turn-signals and a 12-volt electrical system which also powers a self-starter. Hand-cranking is a no-no for me because I'm in personal possession of a stack of vertebra and discs seemingly in need of major surgery every eight years. No, because of circumstances, I can't afford to be a purist, but neither have I crossed over to the dark side. See, I'm of the position that part of the warp & woof of the Model T Ford is its famously cantankerous ignition system—one seemingly having been inspired by Great Britain's Lucas Company. Okay, okay; it's not really that bad. Once understood and mastered, the buzz-coils and timer are perfectly tamable, but they won't be as maintenance and trouble-free as the aforementioned Volkswagen distributor.
Simply put, timers are pigs. The fact that a new timer design has come out every year since the Model T started rolling off the assembly line, and that this creative process continues to this very day, is clearly indicative of that. I don't know that one type is much better than another. My car came with a Ford roller-timer with which I have developed a good deal of experience and familiarity; and as it's better to do combat with the enemy one knows rather than the enemy one doesn't know, I stuck with the roller. It's still a pig, but at least by now, I have that porcine SOB intimidated to the point of showing me some respect.
Pig Timer b.jpg (12.13 KiB) Viewed 19622 times
So okay, I'm on my second roller timer. The first one which came with the car when I bought it back in 2010 just plumb wore out. It did give me good, smooth acceleration, but needed cleaning quite often, same as its replacement. This new one, purchased from Lang's, was one of the last rebuilt units overhauled by an old-school machinist/timer expert of sterling reputation shortly before he passed away. It gets a squirt of 5W-30 motor oil every other day the car gets driven and I clean it out with WD-40 and a handful of paper towels every two or three fuel-ups. That seems to keep it more or less happy.
I've learned from experience that when the engine starts acting up, the most probable culprit is that blasted timer.
[/size]
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Sun May 19, 2019 2:44 am
ETimer is my choice and it is Really maintenance free with superior unmatched performance. I have to LOL reading about how guys with other mechanical timers only have to service it once or twice a year. That must be when they take the car out for a drive? Every mechanical timer requires removing the cover and cleaning, lubing or polishing the contacts. Even a disy needs point servicing and adjusting.
I know some guys are using the I Timer and are extremely happy with the improved performance and it also requires no service or adjusting EVER! Just happy driving.
1912 Torpedo Roadster
Doug
First Name: Doug
Last Name: Money
Post by Doug » Sun May 19, 2019 5:13 am
"I have to LOL reading about how guys with other mechanical timers only have to service it once or twice a year. That must be when they take the car out for a drive? Every mechanical timer requires removing the cover and cleaning, lubing or polishing the contacts."
Hmm, Please don't tell my timer that. I bought it in Chickasha in 2006 and it has been in there the whole time. I did open it one day a few years ago out of curiosity to see how it looked. No lube, it just works. I have driven it to the covered bridge tour and back about 750 miles round trip. I drive it about 500-1000 miles per year most years. It runs like a timex, it just keeps on t'ing. It hasn't given me any trouble yet, so please don't tell it that it has been neglected and is worn out. :D
It's Bill
First Name: Bill
Last Name: Hoffer
Post by It's Bill » Sun May 19, 2019 6:58 am
For my car, I had Ron P. rebuild the coils, installed all new wiring from ignition switch to plugs, put in a modern oil seal and centered the timing cover, and installed a New Day purchased from Langs. No issues since. No weak links in the chain. Cheers, Bill
KirkieP
First Name: Kirk
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
Post by KirkieP » Sun May 19, 2019 9:50 am
I like my I Timer. It performed superbly on the California Dreamin tour.
Kirk Peterson
Santa Fe NM
Ruxstel24
Last Name: Hanlon
Post by Ruxstel24 » Sun May 19, 2019 9:58 am
Thomas distributor here.
Easily obtained 6V coil, points and condenser.
I check and adjust the points a couple times a year...
Let the flaming begin !! :P :lol:
mjr
First Name: MARSHAL
Last Name: REYSEN
Post by mjr » Sun May 19, 2019 12:03 pm
I just bought a flip timer yesterday,have not tried it yet .I have new wiring, new rebuilt coils, engine is rebuilt, new gas tank, OF Stromberg carb..So I shell see Thanks for your info. PS. it is a 25 touring with a 26 engine.
Post by Mark Gregush » Sun May 19, 2019 1:34 pm
flip timer? If the engine has been rebuilt make sure the bolt under the timer is pointing the correct direction, head should be on top. If it is pointing the other way, could be shorting out the terminal on the timer when advancing.
Terry_007
First Name: Terry
Last Name: Bond
* REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Chassis
Post by Terry_007 » Sun May 19, 2019 4:30 pm
My New Day has performed fabulously for 20 year now in my 14 touring. Only ever had one issue when I had the engine out a couple of years ago for a transmission rebuild. Cleaned everything and checked the timer, no prob. Put it back together and no start. After a little head scratching I checked the timer and realized the little spring behind the timer brush had somehow fallen out. I substituted the spring from a ball point pen and it has worked fantastically since. I always carry a pen in the tool kit now.
Terry
James_Lyons-WV
Last Name: Lyons
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1915 Touring, 1925 Coupe
Post by James_Lyons-WV » Mon May 20, 2019 4:31 am
Ford Roller... I buy all the NOS/like-new units when I find them because they are cheap and litter the swap meets. I put a new one on every year and keep on motoring. They work great. For some reason, I like my Model T to be a Model T. So the pre-tour maintenance is nostalgic for me.
Post by Wayne Sheldon » Mon May 20, 2019 6:20 am
One of my speedsters had a Bosch DU4 magneto. Loved it. Three other cars had distributors. One came to me with it, two, I installed during restoration because I had them. The rest had roller timers. Too many friends years ago had such bad luck with New Day (probably the bad repos?) timers that I swore I would never use one. However, in recent years the new ones seem to be okay. But I am hopelessly stubborn.
I have enough good roller timers to probably last the rest of my life. I made a jig and reground all the marginal ones I had, they came out nice. And I may consider going to another DU4 (i have one, and most of a mount for it).
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon May 20, 2019 7:47 am
I’d like to hear from people like me who drive their model T nearly every day. I think it’s a very different experience than the occasional drive. And for me it’s also city traffic to work and then pleasure drives in the evenings and weekends. So, more like how they were actually driven back in the model T era.
For 35 years I used Tiger timers which worked fine for a year or so and then the races eventually wore wonky with indentations on the surface. I switched to a flapper style for awhile and liked it, but the contacts seemed to wear quickly. I still keep a good one in my tool box for emergency.
After I rebuilt my ‘23 I used the TW timer for a couple of years and it ran nicely but my experience was that the brushes only lasted about eight months of driving. The coils were all rebuilt and tested. I did install a good seal when I put in the TW and that was a good move.
Right now I’m running with a vintage New Day and an OF carburetor. Still messing around with the OF as there are still some issues with irregular sustained running around 40+ mph. But in the city the speed limit is mostly 30-35 mph and the car is fine at those speeds. I had never used a New Day till now. Runs nicely so far and I like it. Just removed it the other day to inspect and aside from some dust and contact darkening seems fine. Cleaned the contacts with Scotchbrite and put it back in. I appreciate that there is a reliable E timer but I like the idea of using equipment from the model T era. Like I said .. I drive my ‘23 runabout nearly every day and have never had to leave it in the garage because of technical problems. A very reliable car.
Here it is with the pickup box installed for the summer ... in the parking lot of the George Eastman Museum where visitors always think it was George Eastman’s car. ;-)
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Mon May 20, 2019 8:22 am
On all the old cars I mess around with, I never scrimp on a few things....and ignition is on that short list. It's beyound irritating to spend countless hours reviving an old car only to have it run poorly because I've tried to save a few bucks on ignition components. I tend to not be satisfied with a car unless I can give it just the slightest hint that I want it to start and have it spring to life. My 66 F100 just needs the smallest turn of the key and it jumps to life. My 54 Ford tudor is the same way, and I'll make my 24 Touring behave the same way, with the starter or crank handle.
For that reason, I bought an iTimer and the ECCT with the associated software. In addition to using it on my own coils, I plan on using it to help local T guys tune their coils.
Once my shop is built and my T is up and running (both will happen soon if it will ever quit raining in Houston), I want to make myself available, free of charge, to any local T guy needing help with simple repairs on their car. (things like coils, wiring, seals, leaks, brakes, etc)
For what it's worth, the other components I won't scrimp on are steering, fuel system and brakes. I'm ok with stock brakes on a car as long as the engine is mostly stock. My rule is if you go bigger on horsepower, you need to go bigger on brakes. Stock fuel systems are almost always fine, but they need to be clean, tight and in excellent condition. I'm ok with aftermarket ignitions on mostly stock cars if I can completely hide them. Steering needs to be tight and dang near perfect from steering wheel to tires...no excuses. I'll putt around very slowly in my neighborhood with less than perfect steering while I'm getting a car up and running, but that's it.
1924 Touring
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon May 20, 2019 8:29 am
No one has mentioned using a True Fire ignition. I see that they are available from Lang’s but Bittner Engineering’s website is gone. Does anyone know if they are still in business?
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Mon May 20, 2019 8:44 am
We have always used Tiger timers Dad picked up a stock of about 100 nos Tiger timers back in 1965 . The T uses 1 every 2-3 years, and its the roller that wears out. Cheers Colin
George Mills
Last Name: Mills
Post by George Mills » Mon May 20, 2019 9:50 am
I have always used Tiger roller timers...just because the first one came that way and I was able to pick up a bunch of new 1970's version Tigers to have on the shelf.
I have a few Andersons new in a box on the shelf...always ready to try them but you can see how that goes, I have very little wear on the Tigers so the innards of those Anderson will need polishing before I even need to install the Anderson flapper type...
Now...to add to the personality of choice...
I bought the Hack in 2010 and when I took it out for a drive before purchasing it, it started and ran flawlessly. It was understood that the Hack had a Beta test E-timer that would not come with the purchase and a new roller timer would be installed with the sale. I have no desire to use an E, personal choice and not against the technology or the maker as I also got to see his test bench work on his software testing and was really impressed. I'd recommend it for others, just not for me.
It ran OK with the replacement but the roller timer only lasted 100 miles! The 'plastic' between the contacts had wallowed, and one of the contacts had cocked by maybe 20 degrees! It ran like crap on magneto before I found that, would get me home better on batt but it was still a struggle. On looking how wallowed it was, I was concerned that the camshaft might be jumping, but that did not seem to be the case. So...rather than install one of the new Andersons and risk what I thought could be an internal grenade for unknown reasons...I opened one of those 1970-ish Tigers and put it on. Sweet and still in there even thought the car hasn't been used the last year and a half due to health.
My cars tend to be tuned to start easy and even on mag and like I said the Tiger filled the bill nicely. Rather than oil it and clean it all the time, I tried the Royce P. trick after talking to Royce about it and decided to pack the timer housing with grease. As you might expect, the oil type can't 'conduct' and it does take a few pull throughs now to get the roller to mush out any grease that settled on the lobes after setting a bit, but it works and works well enough that I leave it in.
Turns out the wonky timer mentioned from 2010? Was one of the first made by brand 's' and even though I considered 100 miles a little too quick to wear out beyond repair. They told me it was my cam bearing being shot and not their timer...dang that Tiger tho'...must be bulletproof as it has worked fine without wear ever since :):)
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon May 20, 2019 11:58 am
I remember Royce mentioning packing the timer housing with grease. Not sure how my car would start in cold weather with that stiff grease in there. Anyone have experience with this in the upper states?
Tiger Tim
Last Name: Eckensviller
* REQUIRED* Type and Year of Model Ts owned: 1926 cut-off touring
Post by Tiger Tim » Mon May 20, 2019 5:46 pm
Near as I can tell mine has a Tiger timer. I have no idea how many miles were on it when I got it but I tried to drive the T almost every day last summer and intend to do the same this year. So far so good, and the worn out cam seal keeps it well lubricated!
Marty Bufalini
First Name: Marty
Last Name: Bufalini
Post by Marty Bufalini » Tue May 21, 2019 6:32 pm
I bought about 4 NOS New Day timers and I will not use anything else. Low-maintenance and great performance.
Paul w
First Name: Paul
Last Name: Wilcox
Post by Paul w » Tue May 21, 2019 8:28 pm
I have been using a crystal timer. Clean it out once a year put around 3-4 k miles a year. Have it in there for 3 years now
James_B_NC
Last Name: Bennington
* REQUIRED* Type and Year of Model Ts owned: 1921 Roadster
Post by James_B_NC » Tue May 21, 2019 8:52 pm
Using the New-day timer that was on the car when my Great-Grandparents stopped running the truck. Works fine
The forum's resident Millennial.
Stu Tomlinson
First Name: Stuart
Last Name: Tomlinson
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1913 Huckster, 1924 Touring, 1927 Tudor
Post by Stu Tomlinson » Tue May 21, 2019 9:41 pm
All timers are adequate for normal touring and most driving situations if the ignition system is in good shape. I prefer the TW timer because in my opinion it gives a bit better performance in all driving conditions - especially at higher speed hill climbs. The one thing you have to do is clean the carbon dust from the timer at least once a year. At 1500 miles I find that you have to replace the carbon brush. As the brush wears you loose spring pressure against the tip. There is a trade off between performance and reliability with the TW. If I was driving across the country, I would use an ANCO. But for driving about 1,000 to 1,500 miles per year. I find the TW to be best for touring and normal driving around town.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Tue May 21, 2019 9:54 pm
When I first bought the coupe in 1976 I used a roller timer but I had lots of mis-firing. It was suggested I try a Tiger timer which uses a carbon brush on a vertical surface. It was much improved. I now realize that the front cover was not aligned correctly, live and learn. Then I went to a ole used distributor as I was tired of the constant maintenance of the commutator. Eventually the distributor wore out and I replaced it with an E-timer. Oh it’s so much better, almost worth the $400.
The speedster and 14 Touring have used new distributors since I restored them some twenty years ago. The 1909 Touring uses an “Two-piece” timer but so far it’s done zero miles.
Tony Bowker
La Mesa, California
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Aug 15, 2025 4:48 pm
N.O.S. CRYSTAL TIMERS FOR SALE
FOR SALE BY OUR DOWNEAST CHAPTER, ORIGINAL 1920’S CRYSTAL TIMERS THAT
HAVE BEEN MACHINED TO FIT THE TIMER COVER.
PART OF PROCEEDS BENEFIT MTFCA MUSEUM IN RICHMOND, INDIANA
$50.00 (includes postage paid in continental United States)
Mail check made out to: Downeast Chapter MTFCA
To: John Anderson
120 Intervale Road
Temple ME 04984
fireheadman
First Name: Ben
Last Name: Piraro
* REQUIRED* Type and Year of Model Ts owned: 1911 Model-T Pie Wagon
Post by fireheadman » Fri Aug 15, 2025 6:41 pm
I"m learning as I go... but just bought a replacement NewDay for my current NewDay.
Aside from needing to knock the film/glaze off it with an emery cloth it was fine, however the wires are in bad shape so that is why I ordered a new one.
Member: Mile High Pedal Pushers - Denver, Colorado Chapter
https://www.youtube.com/watch?v=e5FPWnxG_9w
Moxie26
Last Name: Jablonski
Post by Moxie26 » Fri Aug 15, 2025 7:28 pm
To: John Anderson
120 Intervale Road
Temple ME 04984
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Fri Aug 15, 2025 8:29 pm
One thing to remember with New Day and lots of other brands of timers is they are not timed like a Ford roller timer. If you use the little sheet metal gage and it's measurement like the Ford manual states with a New Day timer, the timing is more than likely wrong. The only good way to time a replacement timer is with piston and crankshaft position. Others can tell you how to time by piston and crankshaft position. I've worked all day and too tired to explain it and be sure I explained it correctly. I have only used original New Day timers and so far have never had one fail me. I just wipe it out with a red scuff pad and stick it back on. The wires at the timer are usually what fails if I have any issues.
Last Name: Hjortnaes
Post by DHort » Fri Aug 15, 2025 10:28 pm
I-timer. Works great.
Post by Scott_Conger » Fri Aug 15, 2025 10:47 pm
Does it matter that everyone is suddenly replying to a 6 year old post? To a guy who hasn't been heard from in 5 years??
People have been rummaging around the bowels of the internet lately, dredging up ancient posts and then gush all over themselves to answer a question for a guy who is long gone for the past 5 years! It's bad enough we have to deal with BOT's bringing this bilge to the surface and now we have regular posters doing the same.
Are current questions so mundane that we have to go searching for long-solved problems to rehash?
Good Grief!!
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Sat Aug 16, 2025 8:44 am
Good Grief!!
:lol: :roll: YEP! Some of us amongst "our circle" are even calling it "The Borum" as it's really gone down a hole. :cry:
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Sat Aug 16, 2025 10:10 am
I've been using this one for 1300 miles
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Aug 16, 2025 1:06 pm
I visited John Baumgarten, in Schoharie, New York about 25 years ago.
I don't remember the year, but he had just got an award for setting up at Hershey for 40 years without a missed year.
He showed us several Model Ts, some he was trying to sell.
That was the first time I ever saw or heard about the Crystal Timer.
John had one that had been on his T for over 20 years and was still never missing a spark.
John said had driven that T from the Atlantic Ocean in New Jersey to the Pacific Ocean in California about 25 years earlier and it had the Crystal Timer for the trip.
Evidently that was a common past time years ago!
Post by TRDxB2 » Sat Aug 16, 2025 2:03 pm
love2T's
First Name: T
Last Name: Gates
Post by love2T's » Sun Aug 17, 2025 10:57 am
Mark...I don't drive mine every day but darned close to it.
Glad to hear you like/liked your TW but am concerned why your brush didn't seem to last long but you used "months" rather than miles. I will attach 2 pics...one is the timer after over 17,000 miles on it this spring, and one of 3 sample brushes...far left brush at 4,000 miles, middle @ 2K, and far right is brand new. You can see i could, and have, actually gone further on brushes like the far left.
Someone said something about not losing thenlitle "installation wire"...well with practice I can get the timer put back on over the brush WITHOUT the wire. Learned thst early on, as the earliest versions did not use that wire!
