Heinze/KW hybrid
Woody23
Topic author - Posts: 71
- Last Name: Woods
Heinze/KW hybrid
I recently completed a coil project for a ‘13 T. The owner has a Heinze box but wanted KW style coils. So four fresh wood boxes in the form of Heinze but KW points and coils. This is a great option for touring. Use the KW’s for touring and keep the Heinze for show.
David Woods
Williamston T Works (Facebook)
David Woods
Re: Heinze/KW hybrid
well done
- Last Name: Tannehill
- Board Member Since: 2002
David, that’s awesome & nice looking too.
- First Name: Keith
- Last Name: Townsend
Well done, indeed!
Susanne
- First Name: Susanne
- Last Name: Rohner
THAT is impressive!!! Well done!
Distagon2
That is exactly what I should do for my 1912 (I have Heinz coils). I don't know if this is a service you might offer, but I would be interested in a set of coils like that.
Woody23
- Last Name: Woods
I do, I build a lot of these KW conversions. I also build KIngston coils. I attached a few more photos and post other projects on Facebook under Williamston T Works.
You can contact me at 517-927-9232 or dwtworks@gmail.com
I can remember when we had to do that, but then RV started making the correct points. Since the KW points are more common, it probably still isn't a bad idea. I've always used KW coil boxes in my 13's anyway, and like them. RV made me a brand new '13 KW coil from a junk one a few years ago. I have it in my living room on top of my display cabinet. From my own experience, I have found the original 1913 KW coils to be very reliable without having to do anything to them.
Mike Lebsack-Iowa
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Email sent.
Where we you when I went to a Truefire system in 1994 when my chocolate van hit the road? Not that I have ever had any trouble with the True fire, but I did wind my stock of working Heinze coils down from seven to three, before I fitted it. While the True fire continues with its excellent performance, I should probably make alternative arrangements as an insurance policy.
