For those using an OHV, what clutch do you use?
22centerdoor
First Name: David
Last Name: Stauffacher
* REQUIRED* Type and Year of Model Ts owned: 1922 Centerdoor
Post by 22centerdoor » Sun Jul 30, 2023 7:05 pm
I run a RAJO BB head in my centerdoor. Recently, when going up steep hills, I can feel the clutch slip when I really give it the gas. If I back-off a little, the slipping stops. The car is due for a 10-year engine breakdown/check, so I would like some advice from those of you who run an OHV in your Model T, what type of clutch do you use/recommend. Thanks.
Dave
First Name: Henry
Last Name: Lee
Re: For those using an OHV, what clutch do you use?
Post by Henry K. Lee » Sun Jul 30, 2023 7:26 pm
Dave I use Jack Rabbit clutches but do like to set spring pressure at around 1 7/8" and never have problems. I have a high performance overhead set up with over 20 years and still going strong. Just my experience.
Hank
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Sun Jul 30, 2023 9:02 pm
When I first started using OHV I thought I needed Turbo 400 clutches. I've got more experience now, and use the stock clutches. This gives a cushion when shifting. Clutches and the brake drum lugs must be in excellent condition.
Ron Patterson
Post by Ron Patterson » Sun Jul 30, 2023 9:32 pm
David
Tnry givint each clutch lever one turn.
Ron Patterson
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Sun Jul 30, 2023 10:56 pm
Stock clutch disks handle the greater torque experienced with an overhead and often last longer. Just my experience.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Mon Jul 31, 2023 9:37 am
Stock but make sure where the plates engage isn't worn, this is where the later transmission is beneficial.
Post by TXGOAT2 » Mon Jul 31, 2023 10:31 am
Is the TT clutch spring adjustment spec the same as the car? Is the spring the same?
Post by speedytinc » Mon Jul 31, 2023 11:05 am
Same........
Post by Norman Kling » Mon Jul 31, 2023 12:07 pm
Be sure the parking brake rods are not adjusted too long. If the parking brake lever is all the way forward and you push the neutral pedal it can cause the parking brake lever to slip backward a notch or so, then when you let the pedal out into high the bolt is still on the cam which slightly loosens the clutch.
YellowTRacer
First Name: Ed
Last Name: Archer
Board Member Since: 2009
Post by YellowTRacer » Tue Aug 01, 2023 4:32 pm
Stock Non 26/27 transmission. Rajo BB engine. Pretty sure that I've been running the same one for 56 years.
Ed aka #4
walber
First Name: Walt
Last Name: Berdan
Post by walber » Tue Aug 01, 2023 5:25 pm
Stock disks in a 26/27 transmission with good clutch engagement surfaces and a 110 lb spring. Works fine. Tried a WATTs once maybe 10 years ago, bad news in my application, possibly great elsewhere.
