WHO IS MAKING TAPERED FRONT SPRINGS?
Stephen1915
First Name: Stephen
Last Name: Noll
* REQUIRED* Type and Year of Model Ts owned: 1916 Coupelet & 1911 Torpedo
Post by Stephen1915 » Fri Aug 11, 2023 11:26 am
Looking for contact information on the person(s) that make tapered front springs. In need of a NEW one.
Thanks!
Sarikatime
Last Name: Seress
Re: WHO IS MAKING TAPERED FRONT SPRINGS?
Post by Sarikatime » Fri Aug 11, 2023 11:51 am
Stephen, as I told you and sent pictures of my new tapered from leaf springs, they are not like the originals.
Advertise that you need some nice original springs that are not tired.
There are plenty out there if you get after it.
Hershey swap meet is pretty soon.
You are intending to use these springs on a car that will be judged so you need originals either cleaned up or in really nice condition.
All the vendors have used parts, call them!
Frank
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Fri Aug 11, 2023 12:09 pm
Frank, they are close enough for me.
Post by Original Smith » Fri Aug 11, 2023 1:04 pm
Close enough is not good enough! If you are going to remake a part do it correctly just like the original. Many years ago, I started making exact reproductions for that very reason. There is no excuse for cutting corners.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Aug 11, 2023 2:24 pm
Stephen,
Tapered leaf springs are more difficult to produce, why? Because the temper on the ends are different than the centers, this is called progression hardening. I can almost guarantee the reproductions do not work as well because they are tempered as one equal temper. Try finding a really good blacksmith, they are out there now as hobbyist, and they like finding the old ways to retremper/arch yours back.
Just Sayin'
Hank
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Fri Aug 11, 2023 3:13 pm
So Larry… are you going to make me a spring or share the contact of the individual doing so?
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Fri Aug 11, 2023 3:46 pm
Stephen,
Just Sayin'
Hank
That’s very interesting. I did not know the ends had a different temper, I simply thought they were thinner, and that made the car ride better. Thank you for the information, Hank.
-Stephen
Post by Original Smith » Sat Aug 12, 2023 10:51 am
I know the feeling. I bought a 1913 several years back that had an aftermarket front spring. I advertised and advertised, and finally did find an original. I believe part of the problem is people who have converted 1916 and later T's to so called 1915's. This is especially true here in California. Keep on trying! It took me over a year to find one. You won't regret being patient.
Post by TRDxB2 » Sat Aug 12, 2023 11:34 am
Thanks!
You might try to contact Bob , FATMAN on the forum email, for original used leaves or spring.
Last Name: House
Post by George House » Sat Aug 12, 2023 12:03 pm
I rummaged around in the parts loft and found this: It’s a peculiar taper leaf front spring. Holes in the main leaf for oilers. The main leaf and top 2 leafs have bolt holes but other 4 don’t. And 2 clips are riveted to a leaf. $100 should be reasonable enough…..
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Sat Aug 12, 2023 11:52 pm
Appreciate the help and offers so far, I have reached out to Bob. I have bought many quality parts from him in the past. Hopefully he can help in this case.
The spring style I am after is the type with the curled over leaf that retains the spring clip bolt. The reproductions currently made are made this way, and are very close, close enough that I can alter it to my standards. If I could get the name and number of the gentleman that was supplying them to Lang’s it would make things easy.
With all that said, I am still on the hunt.
Post by Original Smith » Sun Aug 13, 2023 1:14 pm
Ford made the springs two ways in 1913 &1914, with and without curled leafs.
Stephen1915
First Name: Stephen
Last Name: Noll
Post by Stephen1915 » Sun Aug 13, 2023 5:16 pm
Spring is for a 1915 chassis
