high low bulb socket
grizzledmike
Topic author - Posts: 1
- First Name: michael
- Last Name: cox
does anyone know where I could get some headlight sockets high low the part where the bulb goes into
Tadpole
- First Name: Tad
- Last Name: Glahn
Re: high low bulb socket
Do you mean these? Snyder’s should have them, part#T-6574-X
- Attachments
- ED31FF10-BACD-43D7-AD22-196C94108907.jpeg (26.36 KiB) Viewed 1421 times
Bill Robinson
- First Name: Bill
- Last Name: Robinson
Read this thread from a day or so ago. Lots of discussion about the headlight sockets and any vendors who has any in stock.
https://www.mtfca.com/phpBB3/viewtopic.php?f=2&t=37785
mike catlin
- Last Name: Catlin
- * REQUIRED* Type and Year of Model Ts owned: 1923 depot hack
Maders model t parts had them in Wisconsin
Are referring to the socket to fit bulbs with offset pins?grizzledmike wrote: ↑Wed Aug 23, 2023 2:33 pmdoes anyone know where I could get some headlight sockets high low the part where the bulb goes into
The normal setup was weither a BA15S (single contact) or BA15D for (Double Contact). Sockets for bulbs with offset pins are BAY15S or BAY15D.
Since BAY15 style bulbs are normally brighter & perhaps the source of the question. But I am unaware of Model T sockets with off set pins. Most users simple break off the high pin without issue. Other use LED bulbs. Trying to fit a BAY15 socket will require a tab to allow for adjusting the bulb to meet the focal point of the reflector
Arbs
- Last Name: A
- Board Member Since: 2022
A couple of weeks ago double pin light sockets were out of stock at Langs, Snyders, MACs, and Smith & Jones. Chaffin's had them but they confirmed that they are struggling to order more. You may want to pick them up from Chaffin's while you can. Chaffins: (951) 226-7331
Availability across vendors may have changed since then.
RVA23T
- Last Name: C
Might try here for sockets and led bulbs
www.ledlight.com/ba15d-socket.aspx
If you are looking for this, I have several new & used. email or PM me if you need themgrizzledmike wrote: ↑Wed Aug 23, 2023 2:33 pmdoes anyone know where I could get some headlight sockets high low the part where the bulb goes into
- Attachments
- sockt...........png (86.72 KiB) Viewed 1169 times
