Angle of the windshield of a '26 roadster
Will Brown
First Name: Will
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 26 Runabout
Post by Will Brown » Fri Aug 25, 2023 4:21 pm
I am about to install the top and side curtains of my 26 Roadster. At what angle should the windshield be? Is it straight up and down, or does it have a rake to it? If it has a rake, how much should it be?
Thanks!
Professor Fate
Last Name: S
* REQUIRED* Type and Year of Model Ts owned: '23 and '26
Re: Angle of the windshield of a '26 roadster
Post by Professor Fate » Fri Aug 25, 2023 4:50 pm
On a '26, the windshield brackets mount with 3 bolts per side to the cowl. The '26 brackets have a rake or sweep to the rear from the front of the car.
The brackets pictured are only as high as the bottom glass.
________________
**FATE**
Post by Allan » Fri Aug 25, 2023 8:17 pm
The angle is set by the three bolts and corresponding holes in the pillars and the cowl. The angle is not adjustable, though there may be a little wriggle room in the bolt holes to help get them aligned with each other. Once you have them aligned, the new top is made to conform to the setting
As stated, your pillars have been cut off just above the lower pivot point.
Post by Norman Kling » Fri Aug 25, 2023 8:23 pm
Those brackets don't look right. The top of the bracket should have a post where the front bow bolts. It is a bit hard to see in the above pictures, but the touring is same as the Roadster. Note: there are two holes for the windshield sections. I think your brackets have been shortened to make a speedster.
Post by John kuehn » Fri Aug 25, 2023 8:28 pm
I have to say the primed brackets aren’t correct for a 26 Touring or Roadster. As far as the rake goes it’s determined by the bracket angle when it’s attached to the body. Norms correct on this..
Post by Norman Kling » Fri Aug 25, 2023 8:33 pm
I found a better picture which shows the top of the post. That small part at the top is where the front bow clamps to the post.
Professor Fate
Last Name: S
Post by Professor Fate » Fri Aug 25, 2023 8:52 pm
The primed windshield posts in the above pic that you saw, have been cut down for only one pane of glass. They are at the stock correct angle, and were mounted on the cowl of my '26 as Henry intended. No modification there. Here's a pic of my car with a full windshield with 2 panes of glass.
And here's a pic of my speedster after restoration with the shortened posts you saw pictured in primer above.
Last edited by Professor Fate on Fri Aug 25, 2023 11:20 pm, edited 1 time in total.
________________
**FATE**
Post by TXGOAT2 » Fri Aug 25, 2023 9:36 pm
If you use '26 or '27 windshield posts on an unmodified '26 or '27 body, the windshield angle will be correct.
It's also important that the rear top bow angle be correct for the top to fit and look like it should.
Be sure you have information on how to position the rear top bow.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Fri Aug 25, 2023 9:53 pm
Will,
Can you post a picture of your car.
Will Brown
First Name: Will
Last Name: Brown
Post by Will Brown » Sun Aug 27, 2023 10:54 am
Here is a photo of my roadster. I think the question has been answered that there is a slight slope to the rear of the windshield stantions. Here is a picture of the T before I added the headlights.
Post by speedytinc » Sun Aug 27, 2023 12:35 pm
................If the W/S stanchions are not bent or were not bent & straightened not quite right.
I have seen stands on a restored 23 touring that were ridiculously bent too far back. Owner was not aware.
Sands a factory spec, I would compare my mounted set to factory car photos. That was how I set the rear bow angle also.
Last Name: House
Post by George House » Sun Aug 27, 2023 4:57 pm
Will,
…Your windshield stanchions are correct………. Just because they look like mine 😜 …and your wheels are of a nice color - although they’re not dusty 😜
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Tue Aug 29, 2023 5:09 pm
Hello Will,
Go to my post of Jan 21/19 called Improved Open Car Surgery and Build. Scroll down to where I show the vertical straight edge. The forward edge of the front roof bow aligns perfectly with the hinge pins. These cars were designed on a graph with verticals, horizontals, and compass drawn arcs.
Ken
Work honestly
Stay true to your word
Get the job done right
