Original Style Pruden Front Wheel Felt Seals
ShirkWood
First Name: Verne
Last Name: Shirk
Post by ShirkWood » Fri Aug 25, 2023 6:45 pm
I tried searching on the Forum but have not found an answer to this question. I would like to restore the original Pruden front wheel felt grease seals on our T. I've looked a little for the felt but am not sure of the density of felt to purchase. I think it would be in the F3 or F5 range. The timing gear cover on our '14 engine also has provisions for a felt seal where the camshaft come through the timing gear cover. It is unlike any timing gear I have seen before. It has a u-shaped recess that had a felt washer in it. The felt washer kind of looks like a flat washer. I'm guessing Ford used the same density of felt as they did on the wheel bearing, but not sure. Grainger (as well as other places) have nice descriptions of the different types of felt. Any thoughts? Any ideas how to cut a ring of felt out of a sheet?
Thanks!!!
Verne Shirk
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Original Style Pruden Front Wheel Felt Seals
Post by Dan McEachern » Fri Aug 25, 2023 6:52 pm
McMaster-Carr Supply might well be better source of felt material than Grainger. Can you post some pictures of what you need this felt for?
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Aug 25, 2023 6:56 pm
Cutting felt is normally done by a punch method.
Hank
Post by speedytinc » Fri Aug 25, 2023 7:01 pm
Doesnt the inner felt seals come as part of a complete felt seal set?
Langs lists them 09-27 loose for under a buck.
ShirkWood
First Name: Verne
Last Name: Shirk
Post by ShirkWood » Fri Aug 25, 2023 7:36 pm
As soon as I can figure out how to post a picture of the timing gear cover camshaft seal, I will. Verne
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Aug 25, 2023 7:53 pm
The plain felts for the front hub seals are available from all the parts suppliers. Same as the one that goes in the rear hub.
ShirkWood
First Name: Verne
Last Name: Shirk
Post by ShirkWood » Fri Aug 25, 2023 10:26 pm
Felt seal that came out of the timng gear cover camshaft hole.
ShirkWood
First Name: Verne
Last Name: Shirk
Post by ShirkWood » Fri Aug 25, 2023 10:34 pm
Hole in timing gear cover for camshaft seal. Most of them I have seen you were able to press in a lip seal. This one has a groove for the felt in the previous photo. I have seen felts (in the past) that the suppliers sell and they don't seem dense enough.
Post by Rich Eagle » Sat Aug 26, 2023 11:29 am
I had great fun reshaping the housings for those seals. I used rear axle felt and cut it thinner for them.
It's nice that you are trying this.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat Aug 26, 2023 3:58 pm
If you send me your front cover, I’ll re-machine it for a modern seal for $80 and will include the new seal.
