Accessory intake manifold
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Mon Aug 28, 2023 12:26 pm
I have has a few of this long time ago, anyone have any ideas what this was sold to do? Bob
also, no chamfer on flange
Re: Accessory intake manifold
Post by Norman Kling » Mon Aug 28, 2023 12:29 pm
I wonder what that bracket is for? It doesn't have a hole drilled for a pipe or valve in the intake and other than that bracket looks like a standard manifold.
Post by TXGOAT2 » Mon Aug 28, 2023 1:11 pm
I've never seen one of those. I'd guess it had a small cast iron pot that bolted to it. Put kerosene or gasoline in it and light it and let it burn off, then (maybe) start the car on a cold morning.
FATMAN
First Name: ROBERT
Post by FATMAN » Mon Aug 28, 2023 2:05 pm
it was posted on the forum years ago but can't find it now. Bob
Last Name: Juhl
Post by Oldav8tor » Mon Aug 28, 2023 2:13 pm
Whistle connection?
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Mon Aug 28, 2023 2:41 pm
Could it be a mounting for a shroud around the exhaust manifold for a cab heat system?
FATMAN
First Name: ROBERT
Post by FATMAN » Mon Aug 28, 2023 2:44 pm
if I remember the mount had a bracket with a glass jar, wish I could find the post it was a factory made intake, Bob
Post by speedytinc » Mon Aug 28, 2023 2:47 pm
That narrows it. A vacuum intake motor oiling system.
"Top cylinder lubrication."
Post by TXGOAT2 » Mon Aug 28, 2023 3:05 pm
"Marvel Inverse Oiler"?
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Mon Aug 28, 2023 4:12 pm
With the pipe fitting boss in the top of manifold and with that mounting on the side of manifold my guess is that it was for water injection. It was a common way for stretching gas mileage in the WW 1 era due to the poor quality of the gas.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Mon Aug 28, 2023 4:19 pm
