Brass windshield bumpers
RGould1910
Topic author - Posts: 1208
- Last Name: Gould
Anyone know the dimensions and location of the bumpers used on brass windshields? I know they are attached somewhere to the lower frame to keep the upper frame from banging together when lowered. I assume they are made of rubber and are screwed into the frame but that's just a guess. If anyone has a photo I'd appreciate it.
ModelT46
- First Name: Darel
- Last Name: Leipold
Re: Brass windshield bumpers
If you do not find originals, temp ones can be used. Any office supply or picture frames shop has nice bumbers that stick on.
KimDobbins
- First Name: Kim
- Last Name: Dobbins
Richard, I've only seen them on automatic windshields. I believe there is a small piece of brass rod brazed into the frame and then a white rubber cap fits over the rod. It may be held in place by a screw. Just my .02.
RGould1910
- Last Name: Gould
Thanks Kim and Darel. At one time I had a windshield with one bumper remaining but it was not an Automatic. I'll see what I can find retail.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Richard, to kinda 'muddy up the water', there is another option for you since you have a sample to work from. We use a 3D printer at my shop to replicate small things such as that very thing which helps us in one-off restoration work. In your case, you might have a high-school or college drafting class draw your windshield's rubber bumper in CAD, and then find someone to 3D print a bumper mold in tandem out of either PLA or even ABS plastic. This would allow you to print 2 bumpers simultaneously. Locate and mix some semi-rigid off-white rubber. Then cast (fill) your molds with the white rubber to replicate the bumpers.RGould1910 wrote: ↑Tue Aug 15, 2023 9:03 pmThanks Kim and Darel. At one time I had a windshield with one bumper remaining but it was not an Automatic. I'll see what I can find retail.
Is this anything like you are talking about?
If so, I'll take some dimensions and better pictures.
RGould1910
- Last Name: Gould
Thanks for the suggestions, fellas. What I see in your photo doesn't resemble what I remenber, Rich. Thanks for the reply and offer though.
Sorry it didn't help. For reference, mine is a Springaction.
Russ_Furstnow
- First Name: Russ
- Last Name: Furstnow
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1911 Torpedo,1913 Touring, 1914 Runabout, 1915 Coupelet, 1916 Coupelet, 1917 Coupelet
Richard, I have an Automatic windshield on my Torpedo and it has white rubber bumpers on the lower half of the windshield. I don't know if this is what you are looking for or not. Russ Furstnow
RGould1910
- Last Name: Gould
Russ that's what I envisioned. I'll have to do some thinking how to attach them.
Brad Van Meter
- First Name: Brad
- Last Name: Van Meter
Here is an option - drawing is included in post.
https://www.boatoutfitters.com/small-re ... scZVtRLNef
RGould1910
- Last Name: Gould
Thanks Brad
RGould1910
- Last Name: Gould
I've puchased some rubber bumpers ans wish to attach them with screws. Im thinking of screwing them into the bottom horizontal frame just inside the clamps on the outer edged of the firewall. Here's the rub. I have a Speedway Motors windshield frame and don't know if the slugs on the bottom curved corners extend far enough toward the middle of the frame so my bumper screws will bed into the slugs. Ant thoughts?
ahovey
- First Name: Austin
- Last Name: Hovey
- * REQUIRED* Type and Year of Model Ts owned: ‘11 Torpedo
- Board Member Since: 2014
I had both a Rands and an Automatic ‘11 Torpedo windshield. The Automatic had the screws in place for the bumpers and the Rands had original bumpers intact. Here’s a picture of the Rands.[image][/image]
Here is a photo of a late 1910 square tank Torpedo courtesy of the Detroit Public Library showing what appears to be a Rands windshield and black bumpers. https://digitalcollections.detroitpubli ... a%3A174631
I have also seen photos of ‘11 cars with what certainly look like white or lighter colored bumpers.
