Front License Plat Mounting
Ron Patterson
Post by Ron Patterson » Tue Jul 04, 2023 7:26 pm
anyone know of a front of car drivers side license plate mounting available for a 1915 Model T?
The car I purchased had a passenger side mount which I removed because it interferred with the correct choke pull rod. Additionally it doesnt work well on the dirver side.
Ron Patterson
Re: Front License Plat Mounting
Post by RajoRacer » Tue Jul 04, 2023 7:46 pm
Hey Ron - the Canadian mount works great for bolting to the d.s. head lamp post - I have a photo somewhere.
A bit hard to see but I have one on the Centerdoor - see the yellow plate ? I'll get a better photo of one.
Ron Patterson
Post by Ron Patterson » Thu Sep 14, 2023 6:11 pm
Steve
When I got my 1915 Runabout it had a poorly made aluminium reproduction Canadian style license plate mounted on the passenger side headlamp stancion. This positioned my 1915 Michigan plate too close to the choke pull rod loop and in the way of a clear swing of the hand held crank handle. I tried the repro on the drivers side and because of its odd alignment coiuld not get the plate perpendiculart to the ground or at right angles to the verticel side of the radiator and the plate was angled and looked goofy!
Bob C. helped me find with an original Canadian license plate (drivers side) mounitng bracket and I moved the plate to the drivers side
Looks ok now. Here is a photo.
Thanks for your input.
Ron Patterson
Post by Mark Gregush » Fri Sep 15, 2023 11:16 am
Ron Patterson
Post by Ron Patterson » Fri Sep 15, 2023 4:08 pm
I did use a factory styoe unit.....from Canada
Ron Patterson
Post by Ron Patterson » Fri Sep 15, 2023 4:17 pm
Canadian Factory
Post by Mark Gregush » Sat Sep 16, 2023 1:41 am
OK, but you have a USA plate on the car and you live in the USA. ;)
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Sep 16, 2023 7:01 am
Early Fords had no provisions for mounting a license plate, there was no factory bracket front or rear. Ford eventually had a combination tail lamp and license plate bracket, but still no front bracket until well into Model T production. A popular method for displaying a front plate as seen in old photos is a bracket mounted on the radiator neck, or hang below the front axle on straps, or attached directly to the firewall, none of which are practical nor desirable for a collector car today. The Canadian front plate holder fits, keeps the plate away from the swing of the hand crank, off the ground, and off the radiator, it looks good, is of the period, and is practical. I like it. Today, many states no longer issue a license plate for the front, and many cars once again come from the factory without provisions for mounting a front plate. And only recently did my state finally eliminate the slots in the license plates for hanging them by straps.
WayneJ
Last Name: Jorgensen
Post by WayneJ » Sat Sep 16, 2023 9:48 am
The license plate bracket referenced above via a link to the Langs catalogue does not fit a 1915 Model T.
Wayne Jorgensen, Batavia, IL
1918 Runabout
Post by RajoRacer » Sat Sep 16, 2023 10:11 am
VinTin23
First Name: Marty
Last Name: Ray
* REQUIRED* Type and Year of Model Ts owned: 1916 Runabout, 1922 Roadster
Post by VinTin23 » Sat Sep 16, 2023 10:32 am
The second one does - https://www.modeltford.com/item/3664E.aspx
These are not sized correctly as originals and interfere with the crank.
Post by RajoRacer » Sat Sep 16, 2023 11:54 am
If you say so - never used them. My anti-theft device has them built in !
John Heaman
Last Name: Heaman
Post by John Heaman » Sat Sep 16, 2023 12:49 pm
That is what I found also. Below is a picture of a style that have a bend in them and I believe would clear the crank. I found the picture on a forum. Could the new license holder be bent to the same shape?
MarkS
Last Name: Sumner
* REQUIRED* Type and Year of Model Ts owned: 1915 Ford Model T Touring
Post by MarkS » Sat Sep 16, 2023 6:05 pm
I have a bracket I took off the left side of a ‘15 touring over twenty years ago. It is cast, and clamps to the vertical mount for the headlight. Looks like it could be used for either side.
If it’s something you could use, it’s yours for the price of shipping from California.
Ron Patterson
Post by Ron Patterson » Sat Sep 16, 2023 6:38 pm
Mark
Sent you an email.
Ron Patterson
WayneJ
Post by WayneJ » Tue Sep 19, 2023 8:44 am
I am also looking for a driver's side (left side) front license plate bracket, if anyone has a spare. I posted an ad in the classified section.
1918 Runabout
Last Name: House
Post by George House » Tue Sep 19, 2023 9:42 am
Wayne, better be specific and identify ‘left side’ or Allan from down under will jump onto you like a bird on a junebug. He drives on the right side 😜😜
John Heaman
Last Name: Heaman
Post by John Heaman » Fri Sep 22, 2023 2:16 pm
Actually left and right are the same down under as here...they just drive upside down! :lol:
Post by Norman Kling » Fri Sep 22, 2023 4:32 pm
Now you are being silly. Everyone knows the earth spins on the axis which is straight across and whether right side up or upside down only lasts about a second. It takes 24 hours to turn all the way over :lol: :lol: :lol:
