Odd running board fitment on my 1913, any ideas?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Fri Sep 29, 2023 8:12 am
Hello all, I have a question about fitment of my front fender and running boards, when I bought the car they were pushed down where the rear tab of the front fender meet with the front of the running board. I took em apart and those bolt holes aren't even close to lining up?!
Wanted to ask what I am missing here? I am pretty sure these are the correct running boards but my bolt holes end up about 1" apart at normal level height with the fender. (in the pics they are unbolted)
Any insights, or solutions?
Thanks,
James Chochole
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Odd running board fitment on my 1913, any ideas?
Post by ThreePedalTapDancer » Fri Sep 29, 2023 8:49 am
Do you have the correct wood block in there?
Post by Jerry VanOoteghem » Fri Sep 29, 2023 9:32 am
Do the holes in your running board brackets line up?
Fozz71
Last Name: Chochole
Post by Fozz71 » Fri Sep 29, 2023 10:44 am
So, yes I did have wooden blocks but once I took it apart the holes are still at a huge angle and the bolts would not cleanly go in. The holes simply do not line up and I've never had that before.
The gent before me solved the problem by pushing down and bolting the holes once they lined up but it looked very odd and put the running boards at a downward angle towards the front.
My only solution was maybe to make thicker wooden blocks and jack it all up from the bottom and try lining up the holes that way.
Post by Original Smith » Fri Sep 29, 2023 10:49 am
Try using correct 13-14 running boards, and using the correct bolts with them! If the front fenders are reproductions, they usually need a bit of tweaking to get them to work. If the wood blocks are repro's they can be problematic as well.
Last Name: House
Post by George House » Fri Sep 29, 2023 11:39 am
Put the emergency brake on. Remove front fender(s). Grab that fender/headlamp bracket and pull it forward until fender and rb holes match up.
George Mills
Last Name: Mills
Post by George Mills » Fri Sep 29, 2023 12:17 pm
Yay other George!
When I put a car back together, I always just hang the front fender in space...then do the fender bolt up to the running board and the back fender with the bolts but hand tight...and then move/lift/angle/twist the front fender iron until it all works for bolt up and level...haven't had one yet that has failed to come in.
Fozz71
Last Name: Chochole
Post by Fozz71 » Fri Sep 29, 2023 1:26 pm
Thanks, George2,
Alrighty, that is what I shall do- I appreciate the tips and explanations, Gents!
I'll let ya know how it goes.
Post by Allan » Fri Sep 29, 2023 6:10 pm
Part of George's fix needs to consider the bolts that hold the apron down on the frame. These need to be loosened to allow the fender to move. If it can't move there, the rear cant shift. You may need to elongate the frame bolt holes a little. See if you can put all the fastenings in before tightening any of them. Levering stuff into place and doing things up under tension might well induce cracking in the panels at stress points.
Hope this helps.
