Split rims for wood wheels
Tekirgis
Last Name: Kirgis
* REQUIRED* Type and Year of Model Ts owned: 1926 fordoor
Board Member Since: 2024
Post by Tekirgis » Sat Sep 30, 2023 4:43 pm
Does anyone know if new split rims for wood wheels are available. I think the size is 21” . It is for a 1926 fordoor
Re: Split rims for wood wheels
Post by Norman Kling » Sat Sep 30, 2023 4:48 pm
You might find some at Hershey or other swap meets. Good used ones are still available. I don't know of anyone producing new ones.
Tekirgis
Last Name: Kirgis
Post by Tekirgis » Sat Sep 30, 2023 4:52 pm
Thanks that is what I thought
Post by Allan » Sat Sep 30, 2023 8:33 pm
I believe new ones are available from Vintage Rims in Queensland, Australia.
Last Name: Patrick
Post by jiminbartow » Sat Sep 30, 2023 8:36 pm
Why do you need new rims? Split rims can rust quite a bit and still remain useable. I have my 5 originals 21” split rims that came on my 1926 coupe when I bought it in 1970. While they have deep rust pits on the inside, they are still useable and strong 53 years later. Jim Patrick
Post by Allan » Sun Oct 01, 2023 5:07 am
Many 21" rims show deep test pits adjacent to the split because that is where the water gets in. I have rejected many some of which had already let go at the sides by the split. Then there are the problems with the latches on our Canadian sourced rims.
Alln from down under.
Scott C.
Last Name: Clements
Post by Scott C. » Sun Oct 01, 2023 11:40 am
I have a set of reproduction 21"split rims on my 26 coupe. They were mad by Stephen Hood. He is Vintage Rims Australia. I also have a set of 30x3.5's on my 25 pickup.
Tekirgis
Last Name: Kirgis
Post by Tekirgis » Sun Oct 01, 2023 4:55 pm
Thanks Scott I will check that out
Post by Allan » Mon Oct 02, 2023 7:35 am
There you go Tom. Direction to a source in one post and a testimonial from a happy customer in another. Steve does beautiful work. He is a great supporter of our Model T National Rallies.
