1911 brass radiator drain plug size
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Wed Oct 11, 2023 7:07 pm
I picked up a decent 1911 Brass radiator just before Hershey. I would like to test it out, but do not know ow the correct thread count and 'bolt' size which would fit in the drain hole where the petcock would go. Is anyone aware of what the size of those petcock threads might be? Thank you in advance. ** Updated with photos **
Re: 1911 brass radiator drain plug size
Post by Mark Gregush » Wed Oct 11, 2023 7:16 pm
It is not a bolt, it is pipe thread. Should be 1/8" NPT.
Post by Wayne Sheldon » Wed Oct 11, 2023 8:10 pm
What Mark G said!
FYI. It is however close to a standard bolt thread, a 3/8 - 24 if I recall correctly. Sometimes, if the tapered pipe thread has been overtightened a bit much, the bolt thread can be started in the hole. Do not do that except in an emergency (like in the middle of nowhere and the petcock fell out back there somewhere), as forcing the bolt into the tapered pipe thread will quickly destroy it.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Post by Jack Putnam, in Ohio » Wed Oct 11, 2023 8:24 pm
Use a wood dowel, sharpen the end slightly. Then screw it in place. Won't damage the threads.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Wed Oct 11, 2023 8:27 pm
Excellent idea, I appreciate the assistance. I just want to seal it up to check for leaks.
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Wed Oct 11, 2023 8:28 pm
Of course. I was searching for the right term, but you understood what I was looking for anyways. Thank you.
Andy
Post by Allan » Thu Oct 12, 2023 2:39 am
Just screw a petcock in!
Retro54
First Name: Andrew
Last Name: Blaydon
Post by Retro54 » Thu Oct 12, 2023 5:26 am
Very easy to say if you have one! I do not have any spare sitting around and am not about to purchase one just to test it out.
Post by Allan » Thu Oct 12, 2023 5:36 am
Sorry Andrew. Over 50 years of me collecting T parts means I have ample spares. If it is of any use, you could temporarily screw in the top oil petcock from any T to do your leak test.
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Oct 12, 2023 7:17 am
We all know Henry liked to save dollars and cents whenever he could, seems it took a while on the Pet cocks, the radiator one was part No 3940 with the parts book changing to order and use the fuel tank one 2908 then finally using the oil pan 3079 Pet cock for tank and radiator as well.
