JB coil box 1910 style
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Fri May 24, 2019 5:42 pm
Are new coil boxes made that have JB fittings and will take later coils (1914-27) ? I have the switch and key. If available, does someone wire them?
Hap_Tucker
First Name: Hap
Last Name: Tucker
Re: JB coil box 1910 style
Post by Hap_Tucker » Fri May 24, 2019 9:09 pm
Darel,
Yes both styles are available -- they are made to order.
Info at Lang's see: https://www.modeltford.com/item/4250S.aspx for complete box for use with original 1910-11 style coils
and https://www.modeltford.com/item/5000JB.aspx is the box only for the later coils but it looks like the 1910-11 Jacobson-brown. It does NOT include any of the hardware, coils, or switch etc. But I'm 90% sure the builder can build you whatever you want.
From memory -- NOT that reliable -- I think R.V. Anderson's and his brother probably make them? See the article with a nice JB coil box in their hands at: https://www.hemmings.com/blog/article/t ... -brothers/
Respectfully submitted,
Hap l9l5 cut off
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Sat May 25, 2019 11:19 am
We do make them, but only in the original style to take the original style coils (which we also make). This is because when we got started, there was already a fellow making boxes for the later coils, so that market was covered.
Besides, I have an affinity for keeping things original :)
