Fitting a Model A camshaft to a Model T
Rajo T Speedster
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1918 RHD Speedster
Post by Rajo T Speedster » Mon Oct 23, 2023 10:01 am
Hi
I've seem lots of references of fitting a Model A camshaft to a Model T for improved performance.
Could someone explain how this is achieved. The cam bearing sizes between the two are noticeably different.
John from Perth WA
Re: Fitting a Model A camshaft to a Model T
Post by Rich Eagle » Mon Oct 23, 2023 11:11 am
I machined an A camshaft to fit a T block. I simply machined the cam bearing journals (correction) to about 1" diameter and machined the front for a T cam gear. It took some wiggling and turning to get the cams to go through the bearing holes in the block, but it worked.
Post by Rich Eagle » Mon Oct 23, 2023 11:42 am
Here are photos of it. I had planned to make bronze cam bushings to slide in place.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Oct 23, 2023 12:06 pm
My approach is different. I machine the center and front bearing to run directly in the block (just like on the model A). Then I filed slots for the lobes to slide through. I will try to post some pictures
Post by Norman Kling » Tue Oct 24, 2023 12:37 am
I'm surprised it can be done. I thought the length and distance of the lobes would be different. Also the A has a different firing order so if you use the timer, you will need to change the order of the wires between the timer and coils.
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
Post by Joe Reid » Tue Oct 24, 2023 1:33 am
Model A fires 1-2-4-3 just like a T.
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Tue Oct 24, 2023 8:25 am
There is so much to consider if you do this. If you machine the A cam to fit the bores thrust control must be addressed. Also the front of the cam should have a T nose. Also I feel you should use A tappits, otherwise the duration will change, but lift will increase over a T. The inside of the block will need to be machined on both ends for clearance. This not a job for the weak of heart. I'm sure I forgot to mention something
Post by Norman Kling » Tue Oct 24, 2023 11:58 am
Joe, the Model A fires 1,3,4,2 The Model T fires 1,2,4,3. However the top centers would be the same except that the exhaust stroke and intake stroke would be different. same position of the piston however. If I were looking for performance I would rather buy a new cam designed for higher performance but is made to fit a Model T block. I do not like to do anything which changes the Model T block except to bore out cylinders or re grind valves or insert valve seats.
Post by Mark Gregush » Tue Oct 24, 2023 12:08 pm
The Model A is 1243 same as the T, not 1342.
Dave Sullivan
First Name: David
Last Name: Sullivan
* REQUIRED* Type and Year of Model Ts owned: 1923
Post by Dave Sullivan » Tue Oct 24, 2023 12:57 pm
Rich Eagle, You wrote, intended to use bronze bushings, what did you end up with? Thank you, Dave in Bellingham
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Oct 24, 2023 3:20 pm
I built my first one of these in 1978!
Ran the cam directly in the block cam bores just like the model A. To control the end float i brazed up some spots on the front cover and carefully fitted them to run on the cam gear nut. Installed a VW oil pump on the back of the camshaft and went full pressure. Ultimately a Sherman head and a Stromberg V8 carburetor. In a speedster capable of 100 mph. And a Vega distributor which provides automatic ignition advance. The car is still being driven by a new owner.
Post by Rich Eagle » Tue Oct 24, 2023 4:07 pm
Dave, I didn't ever use the A cam. The machining of it was a great challenge, but I moved on to other projects. It would have been fun to try it in my Roof 8 engine. Perhaps a future task.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Oct 25, 2023 1:00 am
On using A tappets: They are too large to be used in the T tappet bosses. You would have to grind the shanks down in order to make them useable in a T block. Using T or A tappets will not have any effect on cam duration- duration is totally controlled by the cam profile and nothing else.
Post by Jerry VanOoteghem » Wed Oct 25, 2023 11:49 am
FWIW...
Dave Sullivan
First Name: David
Last Name: Sullivan
Post by Dave Sullivan » Wed Oct 25, 2023 12:47 pm
Rich Eagle, Thank you, Dave.
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Wed Oct 25, 2023 1:51 pm
You guys really need to listen to the "old timers" - Dan, Les - they don't guess, they KNOW.
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Oct 25, 2023 3:01 pm
Block modification
Block modification
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Oct 25, 2023 3:02 pm
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Oct 25, 2023 3:04 pm
The last picture shows my latest version and the gear drives a flathead V8 oil pump
Rajo T Speedster
Last Name: Rowe
Post by Rajo T Speedster » Fri Oct 27, 2023 12:08 am
Thanks for the photos, Les.
I think I'll go that way.
The Model A cam being thicker is not as flexible as the Model T so I can increase my valve spring pressure if needed.
John from Perth WA.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Oct 27, 2023 1:04 am
I don’t go with heavier springs on a flathead T engine. Even with a radical cam grind the valves don’t start to float till over 4,000 rpm. I like it as a built in rev limiter!
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Fri Oct 27, 2023 8:38 am
You don't need a T nose if you run a side drive mag. The A cam rides bearing less in a T block. The notches required for fitting can be set using a plug and long drill bit st at about 90 degrees.
Rajo T Speedster
Last Name: Rowe
Post by Rajo T Speedster » Tue Oct 31, 2023 8:37 am
Les, what was your transmission shaft that was discussed many years ago? To reduce vibration?
With regards to this current discussion I am looking to use the Model A cam with an OHV conversion head ie a Rajo BB. So spring pressures may need to be increased.
John from Perth WA
Last Name: Hatch
Post by Dan Hatch » Wed Nov 01, 2023 11:42 am
John: Here is a thread about the Floating Transmission Shaft.
http://www.mtfca.com/discus/messages/50 ... 1438120257
CamMan
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: '26 Tudor, '22 speedster, ABC/Rajo
Post by CamMan » Wed Nov 01, 2023 12:41 pm
I'm surprised no one has mentioned this problem. The foot of Model A lifters is larger, 1 1/8 inch or 1 3/16, for a reason. The contact point will be off the edge of a 1" lifter. You might get by with that for at least a while, but it's not considered a good idea.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Thu Nov 02, 2023 8:17 am
What's your idea "a while"? Mine has been running almost 45 years and as many can attest the previous owner "tested" most everything on the car to the breaking point. . .
Post by speedytinc » Thu Nov 02, 2023 8:34 am
Lots of folks have done the A cam conversion, especially for hopped up motors. Lifter head isnt an issue.
Why go to the trouble of such a conversion? You get a higher lift with a heavier "stick" that doesnt bend & flex.
CamMan
Last Name: Young
Post by CamMan » Thu Nov 02, 2023 1:12 pm
All I can tell you is that an A cam (unless the lobe is reground) will run off the edge of the lifter. Ford and other cam designers don't think that is a good idea. That's why they used a larger diameter lifter in the model A. Your certainly free to do whatever you want.
This has nothing to do with lift. Flathead V8 cams had more lift but would run on a 1" lifter, because,they had an entirely different grind profile,
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Thu Nov 02, 2023 2:44 pm
I wonder if that I ran a significantly reground profile (.325 lift) managed this
