Coil unit capacitor From the mid 60's anyone remember these
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Post by FATMAN » Sun Jul 30, 2023 11:15 am
Back in the 60's my father made the wood coils, boxes were made from scratch in our shop, I just found a few of these Coil unit capacitors
in a box Black Cat does anyone remember these and how good they were? Bob
Re: Coil unit capacitor From the mid 60's anyone remember these
Post by TXGOAT2 » Sun Jul 30, 2023 11:42 am
I believe that one one of many brand names, including Illini Hycap, Solar, etc. If they're 60 years old, they probably aren't as good as they once were.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Sun Jul 30, 2023 12:38 pm
The picture shows that the capacity is .25 mfd. Current capacitors have .47 mfd. At .25 they will probably work but maybe not optimally.
Art Mirtes
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Jul 30, 2023 4:32 pm
I find Art’s comment interesting. I have run ‘60’s era distributor “condenser” for about 50 years and they have worked great. I recently had my coils “tuned” on the latest equipment. In doing so we found that the condensers were about the 025 mfd ! The points have survived quite well for about 10,000 miles! I run my 27 roadster on mag (actually generally start it on mag, often hand crank it).
Just thought I would share this experience.
Ron Patterson
Post by Ron Patterson » Sun Jul 30, 2023 4:51 pm
Robert
Those Black Cat brand, film/foil, 400VDC, .25uF dip coated capacitors, have a high enough dV/dT will work fine in a Model T Fordx ignition coil.
Install two and wire them wired in parralel to get the .5 uF specification for the Model T Ford ignition coil.
If your interested in selling them please give me a call.
Ron Patterson
231-348-5085
JohnH
Last Name: Hunter
Board Member Since: 2002
Post by JohnH » Sun Jul 30, 2023 6:10 pm
I've seen these in the black plastic coils. Problem is they used only 0.1uF.
JEC
Last Name: Cox
* REQUIRED* Type and Year of Model Ts owned: 1915 Runabout, 1925 Pickup
Post by JEC » Sun Jul 30, 2023 7:44 pm
It looks like what the ham's call black beauty's.
when found it radios of that vintage they get replaced.
Duey_C
First Name: Duane
Last Name: Cooley
Post by Duey_C » Tue Aug 01, 2023 2:06 am
Les, thank you for that. Very interesting. :)
Post by TXGOAT2 » Wed Aug 02, 2023 9:00 am
I seen it when I got up this morning. Then it beamed up to the Mothership. (Shriners)
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Aug 03, 2023 7:31 pm
I tested several old coils recently and was surprised to find several with .025 capacitors that seemed to work OK.
I had never seen any that size before.
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 6:45 pm
Closest I could find to my question here. Is this the one I need?
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
JohnH
Last Name: Hunter
Post by JohnH » Tue Oct 24, 2023 8:17 pm
The voltage rating and capacitance are correct, but to use it in a Model T coil requires a high dv/dt rating; something like at least 700uV per microsecond. Unfortunately this specification is often not listed, but it needs to be confirmed before using it. Known suitable capacitors are available from Langs/Snyders, etc.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Wed Oct 25, 2023 1:44 pm
"CBB Capacitor 474 400V 474J 0.47uF 470nF P15 CL21 Metallized Polypropylene Film Capacitor"
Is that dv/dm/whatever you wrote in that description?
I really need to use that " function here more!
JohnH
Last Name: Hunter
Post by JohnH » Wed Oct 25, 2023 6:47 pm
The only specification there is the capacitance value, tolerance, and voltage rating. However, the fact it's polypropylene means that it might have a high enough dv/dt rating.
Looking at the capacitor from Snyders, https://www.snydersantiqueauto.com/prod ... &cat=41844
we can see it's a Sprague (SBE) product. This has a proper datasheet available.
This shows the type 418P capacitor, rated at 0.47uF 400V has a dv/dt rating of 700V/us.
As far as I know, this is also the same capacitor which Langs supplies.
As a point of interest since this supplier no longer exists, Fun Projects also initially supplied the same type:
Later they changed to a different narrower type which actually had a higher dv/dt rating. Its advantage was the glass didn't have to removed from the coil to fit it.
