question for those that know
Gen3AntiqueAuto
Last Name: Foye
* REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 4:15 pm
Who's making the repro "notches" aka "pedal cams"? I have an idea and a request for the person casting them.
and just for fun, here's a link to a video "short". I'll be doing more and more Model T videos over the coming months and hoping to increase my audience. I hope you all will follow along. https://youtube.com/shorts/aonsR8PmTNg
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
BobUkPipedream
Last Name: Dyer
Re: question for those that know
Post by BobUkPipedream » Tue Oct 24, 2023 5:02 pm
Not sure who does them, but the one I got was better than the worn original I had on the brake, but not as good as the slightly worn reverse one, so I put the new one on the reverse and the old reverse one on the brake. Next time I will take my old worn one and build it up with weld instead so I can get it to near new quality.
Post by Allan » Tue Oct 24, 2023 6:10 pm
New notches should not be seen as a cure-all. The notch is one half of a pair of components. Both wear. A new notch takes out some wear. Building up the other piece with weld and dressing it down to suit is the best solution. This is where the true value of a new notch becomes obvious. It can be used as a reference piece when dressing down the welds, to make sure you have the best contact between the two working surfaces. Getting the correct form on the welded ramp takes time and care, not to mention some skill getting BOTH ramps engaging at the same time.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 6:42 pm
You are on the right track with this. Welding up the pedal side is a PITA.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 7:02 pm
I finally found my notebook after 10 years - Is Ken Meek still in here? I have a note in here about pedal cams. I can't remember what it was exactly, if he was welding them up or casting the notches...
Post by Jerry VanOoteghem » Tue Oct 24, 2023 7:04 pm
Ken Meek was tragically killed in a Model T wreck many years ago.
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 7:29 pm
My notes from 2008 are not helping me.... :( Welp - I can start over!
Anyone casting new pedals?
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Tue Oct 24, 2023 7:31 pm
Post by Allan » Wed Oct 25, 2023 7:11 am
Tim, I have done a few of these, but only for my own use. There is too much time involved to take the job on for others.
Early on, I did a first gear pedal/notch set for myself. I thought I had done a wonderful job getting rid of all the slack, only to find that the first gear pedal needs some free travel to be able to hold the clutch disengaged for neutral!!!!!
Live and learn. Allan from down under.
Last Name: Hatch
Post by Dan Hatch » Wed Oct 25, 2023 7:50 am
One thing I have learned is don’t mix a NOS cam with a reproduction slow speed notch. They don’t like each other.
Post by TRDxB2 » Wed Oct 25, 2023 10:01 am
Since the notches are a spiral design they need to match that of the respective pedal. A new notch will not always mate well with a worn pedal.
Here is am older discussion if interested. viewtopic.php?t=15295
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Oct 25, 2023 1:00 pm
If the cam & pedal ramps are good & smooth but worn I weld up the hole in the cam, add some to the outside & mill a new hole to put the
peddle in the correct possion & travel. I only do this on the brake & reverse, low always gets the cam & notch replaced. I also ream & use tapper
pins. I have found broken split pins, bent roll pins & grade 2 bolts in pedals & low notches. I have seen a grade 8 bolt threaded into a low notch.
With the thought that you could replace it without removing the HH??
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Wed Oct 25, 2023 1:28 pm
Since you have to grind off the head and drill the retaining pin on the low pedal - I'm going to say "no".
Gen3AntiqueAuto
Last Name: Foye
Post by Gen3AntiqueAuto » Wed Oct 25, 2023 1:34 pm
New tack - Who's making the repro Rocky Mountain brake pedals?
First Name: craig
Last Name: leach
Post by Craig Leach » Wed Oct 25, 2023 5:44 pm
Hi Tim,
Someone tapped & installed a grade 8 bolt in the notch thinking they could remove the bolt and slip the shaft out and replace the notch & cam
without taking the HH off.
